washer won't spin
I have a maytag washer everything work but when in spin cicle ,drains good but won't spin, can you help me with this problem
Ricky |
Does the motor run in spin?
Quote:
Remove the belt and turn the tranny pulley in the spin direction. Brakes should release and tranny start to turn. If not, you have a worn thrust washer. You will need to buy the pulley and thrust washer kit and follow the directions, am not familiar with this repair, might want to re-post for more info. Also, sometimes if the housing gets wet from a leak, the brakes will stick. Sometimes if you tap on the brake housing while turning, they will release.
Thank you
I,ll do that. But I the washer agitates good also I saw the pulley spining either in agitation or spin cicles. Ricky |
My washer won't spin
Quote:
and started to spin but slow,after that i did run the washer on spin cicle several times and was agitating like it in agitation cicle:confused: Ricky |
You might have a worn snubber if you see white shavings on the bottom of the washer.
| All times are GMT -7. The time now is 01:23 PM. |
