Discuss
Maytag makes noise while spinning
 in
Washer Repair
The shaft is part of the gear case so you have to pull the outer tub to get that out.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag makes noise while spinning
  #21 (permalink)
Old 04-10-2008, 08:43 AM
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
outer tub to get that out. I ran into this before
but I cant remember exactly what I did to get the bearing out.
I think in one case I had to pull the gear case out anyway,
so I just gave the gear case a few good tugs and managed to break
it loose. But yours may be stuck on shaft tighter than that one was.
Maybe setting up an impact or vibration on the bearing itself
will break its grip. You might be able to take a piece of pipe
that would go around the shaft and have the end of the pipe
seat against the bearing itself, make sure its long enough to extend
past the transmission shaft to avoid damage to it, And set some
impact against the bearing itself to try and break its grip. Just be careful
not to damage anything on the transmission shaft.
Hope this helps.
  #22 (permalink)
Old 04-10-2008, 11:19 AM
Junior Member
Lawnboy is on a distinguished road
Default
Thanks for sticking with me on this one. I tried an air hammer and cutting tool to no avail. Just dulled the tool. I used a deep socket on the shaft and hit it with a hammer a few times, didn't budge. I am heading to home depot to buy a dremel drill and a cutting tool to see if can cut it off. If that doesnt work, I will be asking you for instructions on how to remove the transmission. You know, this is discouraging as I can usually fix most things. The tub and bearing seals were a piece of cake compared to this. I was told that the lower bearing is not difficult to replace. I have rebuilt engines in less time than I have spent on this washer.
  #23 (permalink)
Old 04-11-2008, 08:58 AM
Junior Member
Default
Okay, problem solved. I ended up cutting the old bearing off with a dremel cutting tool. I would not recommend this approach as it is time consuming. In the "lessons learned"" section I would advise when replacing the tub seal you take the next step and replace the bearing while the outer tub is already out. The brake was full of water and appears to be working fine after drying out Thanks for all the help!!
  #24 (permalink)
Old 04-11-2008, 12:25 PM
Senior Expert
APP Volunteer
Default
Quote:
It doesnít look like you had much choice.
When I was in the field that was always part of the job.
No, the customer wasnít thrilled about paying the extra
coin for the bearing. But you can better believe they
would have been pissed if I had to go back out and
tear into the washer again because I didnít replace it
to begin with.
Just a heads up,
That break package does have lubrication in it.
You donít need to pull the brake apart to do it.
about a tablespoon of 90 weight oil is all it needs.
  #25 (permalink)
Old 04-11-2008, 01:33 PM
Junior Member
Default
I hear ya. People don't have a problem buying something new but when repairs are needed (and if mechanical it will need service eventually) they will choose the cheapest parts and minimal service required. The repair industry is a tough one and to be successful it helps to be a people person when explaining their options. I do some works on cars, outboards and small engines and I tell people that I would prefer they pay a couple bucks more for quality parts. That way, they won't be seeing me anytime soon. I hear the sweet sound of the washing machine in the backgroud. No more leaks and we don't have to turn the TV up while it's running. Thanks again for your help!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Performa Washer makes loud noise gsgray2806 Washer Repair 1 01-02-2010 06:24 PM
Washer makes loud noise when spinning cindy46748 Washer Repair 0 11-27-2009 06:10 AM
Maytag Dryer makes an awful squealing noise cfoley Dryer Repair 7 05-19-2009 12:28 PM
makes grinding noise when spinning markcopelli Washer Repair 0 06-09-2008 11:18 AM
Makes loud noise when spinning waggie Washer Repair 0 09-03-2007 01:05 PM
