Discuss
Maytag makes noise while spinning
 in
Washer Repair
Probably is different. I soaked it with wd40 and will let it soak for awhile. I will upgrade to a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag makes noise while spinning
  #11 (permalink)
Old 04-09-2008, 11:55 AM
Junior Member
Lawnboy is on a distinguished road
Default
Probably is different. I soaked it with wd40 and will let it soak for awhile. I will upgrade to a 3lb hammer!! Hope I don't break something else. If I do, I may consider getting an Amana. Thanks for the response.
  #12 (permalink)
Old 04-09-2008, 12:04 PM
Junior Member
THOR is on a distinguished road
Default
NO!!!!!!!!!!!!!!
Do NOT get an Amana!!!! - read my post from earlier today.
Although it works great, I've been doing tub seals and bearings on a REGULAR basis.
ugh! (again, Good luck)
  #13 (permalink)
Old 04-09-2008, 12:07 PM
Junior Member
Default
I did remove the drive belt and ran it through the spin cycle as suggested. No noise so I can rule out the water pump. Adding to my preivious post, is there a special process for removing the brake other than beating it with a hammer?
  #14 (permalink)
Old 04-09-2008, 12:27 PM
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Quote:
First you need to make sure that you remove the holding clamp, then
you need one of these..
  #15 (permalink)
Old 04-09-2008, 12:41 PM
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by THOR View Post
NO!!!!!!!!!!!!!!
*chuckle*..I was going to pipe up and warn him
but I didnt want to hurt your feelings
  #16 (permalink)
Old 04-09-2008, 02:40 PM
Junior Member
Default
Yup, that's the wrench. I went against the experts advice and gave the brake a "whack" in the other direction. Came loose right away. Now, the next issue is the bearing is shot, but will not come off of the transmission shaft. There isn't any room to get behind it and pry it off and it is recessed in the transmission cover so I can't get anything on it to pull it free. Do you know if they make a special bearing puller for these? I am considering putting some heat to it. Thanks for all the help and I won't get an Amana!!
  #17 (permalink)
Old 04-09-2008, 02:42 PM
Junior Member
Default
at this point, can you tell if it turns freely and smoothly?
sorry, nevermind. You wrote that it's shot (I need to read slower).
  #18 (permalink)
Old 04-09-2008, 02:48 PM
Junior Member
Default
Wobbles all over the place as it is grinding. Some of the bearings are even flat.
  #19 (permalink)
Old 04-09-2008, 06:44 PM
Senior Expert
APP Volunteer
Default
Just be careful where you apply heat. You could run the risk of
damaging an oil seal in the lower part of the gear case.
  #20 (permalink)
Old 04-10-2008, 05:01 AM
Junior Member
Default
I tried some heat, didn't work. Do you have any ideas that will get this bugger off? Do I have to take the shaft out? I am almost out of patience. I have to believe this is not an isolated problem. I have to take the wrench back today so the clock is ticking. Do you know if there is an on-line repair manual available?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Performa Washer makes loud noise gsgray2806 Washer Repair 1 01-02-2010 06:24 PM
Washer makes loud noise when spinning cindy46748 Washer Repair 0 11-27-2009 06:10 AM
Maytag Dryer makes an awful squealing noise cfoley Dryer Repair 7 05-19-2009 12:28 PM
makes grinding noise when spinning markcopelli Washer Repair 0 06-09-2008 11:18 AM
Makes loud noise when spinning waggie Washer Repair 0 09-03-2007 01:05 PM
