Discuss
Maytag Neptune will not spin or agitate
 in
Washer Repair
The wife switched from cotton/sturdy to delicates cycle and noticed that the washer was not agitating or spinning. On
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Neptune will not spin or agitate
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-07-2008, 09:45 AM
kellyjo kellyjo is offline
Junior Member
kellyjo is on a distinguished road
Default Maytag Neptune will not spin or agitate
Model Number: MAH5500BWW   Brand: Maytag   Age: 1 - 5 years
The wife switched from cotton/sturdy to delicates cycle and noticed that the washer was not agitating or spinning. On the motor control board found the fuse blown, R19, R29, R27, R30 & IC2 fried (electronic smoke theory).
The Motor control board obviously needs to be replaced, is there any thing else?
This is not the first time I've had the pleasure of repairing this fine Neptune washing machine. When it started sounding like a jet fighter when spinning and walking all over the room I called Maytag repair. After picking myself up off the floor after he handed me the cost to repair, (what the washer cost new) I decided to do it myself. I took the washer apart, inspected and cleaned the shaft, knocked out the old shaft bearing, went to the local auto parts and bought the same bearings for $16.00, installed bearing and a new seal kit from AppliancePartsPro. Total repair cost, less than $100.00
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-07-2008, 05:08 PM
bambiblaster bambiblaster is offline
Senior Expert
APP Volunteer
bambiblaster is on a distinguished road
Default
The link below tells what parts went bad to cause the resistors to fry
http://www.servicematters.com/maytag...DL-0052A-B.pdf
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag wont agitate/drain/spin fletch Washer Repair 1 02-09-2008 09:16 PM
maytag will not spin agitate or pump drembo Washer Repair 7 12-25-2007 02:37 AM
Maytag Neptune wont spin Stokes Washer Repair 0 12-15-2007 11:59 AM
Neptune Washer won't agitate or spin birdy Washer Repair 1 12-03-2007 12:23 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
