Problems with spin cycle. Goes through was ok but doesn't ring the water out of the clothes. Still water in the bottom of washer when done and have to ring out clothes by hand before putting them in dryer. :( Getting really :mad: because we spent a lot of money of them. Also, the smell of mildew is always in the clothes.:confused:
Problems with spin cycle. Goes through washing cycle ok but doesn't ring the water out of the clothes. Still water in the bottom of washer when done and have to ring out clothes by hand before putting them in dryer. :( Getting really :mad: because we spent a lot of money of them. This is not the first time have had problems with one of them. Also, the smell of mildew is always in the clothes.:confused:
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Try cleaning out the pump and drain hoses. This service manual will show you how. http://www.servicematters.com/m...ibrary/docs/16010061.pdfAt the end of the day you may need to install the newly designed motor/motor control kit, but let's see if a simple cleaning out of an obstruction will do the job first.
