| » Front load spin problem |
Model Number: LTF 29400ee0 Brand: Electrolux Age: 1 - 5 years
Have a front load machine, it will go through all the cycles, but on the spin cycle it never reaches high speed. It will spin, but it is slow speed. The pump is clean, the belt seems tight. It seems like a senser or a control board?
thanks -Lee Ads By Google Related Models |
Look inside the lower service panel and see if there is a set of tech notes that will allow you to put it into diagnosis/troubleshooting mode.
I would think that your motor/speed control board is the problem but try to verify that with testing. I am also having trouble getting your model number to come up, if you need more assistance please check it and post the correct one, along with the results of your testing.
__________________
Ok, this is the model that comes up with your model number,
LTF2940EE0 and what you posted had an extra zero, but I am going to assume that this is your model. Here is the service manual for that machine. http://frigidaireservicetips.com/pdf...isWasherSM.pdf
__________________
yea 90% the motor control board is the problem. The board is located on the bottom right side of the tub, with the back panel off. But you can test with meter as Sid suggested. But all i have seen, it is the motor control board.
Turn the spin basket and see if it turns "rough", this would indicate bad tub bearings, a common reason for speed control board failures, I believe any current draw above 3 amps will damage the board.
__________________
| Display Modes | |
| GE front load will not spin or tumble | pauldunn | Washer Repair | 4 | 05-25-2010 05:35 PM |
| GE Front Load Problem | junebughoney3 | Washer Repair | 10 | 11-12-2009 05:30 AM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
| front load drain/spin problem | tammyclif | Washer Repair | 5 | 07-25-2009 01:06 PM |
| GE Front load won't spin | lemoncadillac | Washer Repair | 0 | 01-16-2009 03:32 PM |
