Al
afresquez
#1 Posted : Monday, January 18, 2010 8:29:51 AM(UTC)
afresquez
My washing machine doesn't agitate on the wash cycle but it does work on the spin cycle. How do you fix this?
sidfink43
#2 Posted : Wednesday, January 20, 2010 6:25:29 AM(UTC)
sidfink43
Since your machine performs correctly in the rinse cycle, it does not seem like there is a mechanical problem. The problem is likely in your timer not sending the correct electrical current to the motor.
Take off the connection to the timer and clean it thoroughly with contact cleaner and reseat it. Also check all of the wiring between the motor and the timer. If everything checks out, try replacing the timer, this part here.
Part number: AP4024921
water dispenser sporadically dispenses water (Refrigerator & Freezer Repair)
by ddxxoo 3/20/2024 2:55:42 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
Coupling removal tool? (Washer Repair)
by FrankD. 3/13/2024 4:43:18 PM(UTC)
1950s ge wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/8/2024 6:02:49 PM(UTC)
Water inlet valves burning out (Dishwasher Repair)
by Tydinelle 3/3/2024 4:06:06 PM(UTC)
Reserva tu alojamiento para las vacaciones (General Talk)
by Biyen 2/28/2024 11:42:29 AM(UTC)
Frigidaire FGHS2655PF5A Gallery side by side (Refrigerator & Freezer Repair)
by Rube 2/27/2024 7:56:33 PM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
Viking propane range #VGCC530-4B, oven/broiler dead, all other features working (Oven Repair (including Ranges and Cooktops))
by Andy Douglass 2/21/2024 2:06:07 PM(UTC)
Viking Wall Oven VGSO 166 Temperature Probe (Oven Repair (including Ranges and Cooktops))
by RRR5678 2/20/2024 4:15:01 PM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
Roper washer RAL5144BQ1 (Washer Repair)
by Nanabkim 2/16/2024 2:16:15 AM(UTC)
Hotpoint timer stalls in middle of opperation (Dishwasher Repair)
by Fidofax 2/15/2024 8:50:49 AM(UTC)
GE outer tub and seal replacement issue (Washer Repair)
by Bobby0600 2/14/2024 9:06:57 PM(UTC)
Artificial intelligence in companies (General Talk)
by Biyen 2/14/2024 9:28:30 AM(UTC)
