Discuss
Whirlpool with a spin problem, clutch replaced. Hmm...
 in
Washer Repair
Greetings to all. I have search around and found a few things relevant to my problem but I am not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool with a spin problem, clutch replaced. Hmm...
  #1 (permalink)
Old 01-16-2010, 06:04 PM
Junior Member
laser3kw is on a distinguished road
Default Whirlpool with a spin problem, clutch replaced. Hmm...
Model Number: LSR8233EQ0   Brand: Whirlpool   Age: More than 10 years
Greetings to all.
I have search around and found a few things relevant to my problem but I am not sure they full match.
I have Whirlpool model LSR8233eq0. My wife reported that it was making noise and upon searching it was determined that the clutch # 284785 was at fault. It was replaced with a new FSP and put back into service. Also, while I was there I installed a new start cap on the motor. We ran a couple of loads through, but it seems there is still a problem.
I set the timer to spin and, with the lid open, I can use my hand to keep the basket from spinning up with moderate effort. When I let it engage itself, it looks like it does not spin very fast. Our clothes come out wet to where you can wring water out by hand and our dryer time have gone up drastically.
When I had the trans and motor out, I did notice that the trans seem to function "weird". I could turn the shaft quiet a few times before the other shaft would turn at all. Also if I reversed, it seemed the other shaft would not turn at all. If I have the lid open, motor off, what should the basket and agitator do? Should I be able to turn the basket or the agitator Upper / lower by hand? Am I looking at trans problems? If you suggest the brake, how much harder is it just to replace the drive tube?
Thank you,
I appreciate your help.
Ads By Google
Related Models
Whirlpool LSR8233EQ0
Whirlpool LSR8233EQ1
Whirlpool LSR8233EZ0
Whirlpool LSR8233EZ1
Whirlpool LSR8233JQ0
Whirlpool LSR8233JQ1
Whirlpool LSR8233JT0
Whirlpool LSR8233JT1
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0
Whirlpool LSR8433KQ1 Automatic Washer
Whirlpool LSR8433KQ2 Automatic Washer
Whirlpool LSR8433KT0
Whirlpool LSR8433KT1 Automatic Washer
Whirlpool LSR8433KT2 Automatic Washer
Whirlpool LSR8444LQ0
Whirlpool LSR8444LQ1 Automatic Washer
Whirlpool LSR8444LT0
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 Automatic Washer
Whirlpool LSR9434PQ1 Automatic Washer
Whirlpool LSR9434PQ3 Automatic Washer
Whirlpool LSR9434PQ4 Automatic Washer
Whirlpool LSR9434PT0 Automatic Washer
Whirlpool LSR9434PT1 Automatic Washer
Whirlpool LSR9434PT3 Automatic Washer
Whirlpool LSR9434PT4 Automatic Washer
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0
Whirlpool LSS9244EZ0
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
Whirlpool LST9245AN0
Whirlpool LST9245AW0
Whirlpool LST9245BN1
Whirlpool LST9245BQ0
Whirlpool LST9245BQ2
Whirlpool LST9245BW1
Whirlpool LST9245BZ0
Whirlpool LST9245BZ2
Whirlpool LST9355AN0
Whirlpool LST9355AW0
Whirlpool LST9355BN0
Whirlpool LST9355BQ0
Whirlpool LST9355BQ1
Whirlpool LST9355BW0
Whirlpool LST9355BZ0
Whirlpool LST9355BZ1
Whirlpool LST9355DQ0
Whirlpool LST9355DZ0
Whirlpool LSV5132AG0
Whirlpool LSV5132AN0
Whirlpool LSV5132AW0
Whirlpool LSV6233AG0
Whirlpool LSV6233AN0
Whirlpool LSV6233AW0
Whirlpool LSV6234AN0
Whirlpool LSV6234AW0
Whirlpool LSV7233BG0
  #2 (permalink)
Old 01-17-2010, 08:46 AM
Junior Member
Default
Here is a little more info. The agitator seems to work well. It seems to be aggressive and circulates the clothes well. I did notice in the FSP clutch kit, the instructions refer to spring colors. My instructions state:
"To determine which spring to use, match the cabinet style and width of the washer. See chart below".
The chart states:
"Blue spring is factory installed".
Then the chart lists:
24" and 27" regular and over/under, extra and super capacity washers use the Blue spring.
24" compact and 24" over / under use the Black spring.
My washer is a "27 super capacity.
Now here is the weird part, The FSP came with a Blue and a Green spring (where is the black?).
To complicate things further, the old clutch has a Red spring.
Which is the right spring? It may be that the clutch is slipping due to a incorrect spring.
But I can not rule out another problem.
  #3 (permalink)
Old 01-17-2010, 01:45 PM
Junior Member
Default
Another observation.
Just now, we were washing a relatively small load and it was spinning just fine. I had the lid up and had the door switch pushed in so I could observer the load spinning and rinsing. I was happy to see the basket spin at what I consider to be a normal rate. I then released the door switch and the basket slowed to a stop as I shut the lid. When the lid was full shut, I could hear the motor humming softly as it tried to accelerate the basket, but could tell it was not spinning. I opened the lid and pushed the door switch in only to find the basket stopped. I tried to rotate the basket back and forth but it was stuck tight. I then closed the lid again and the basket began to rotate again. I opened the lid and held the door switch again and the basket seem to rotate normal.
Does this scenario suggest a intermittent stuck brake or should I dig deeper?
  #4 (permalink)
Old 01-20-2010, 05:39 PM
Junior Member
Default
still no thoughts? any thing to point me in the right direction would be appreciated.
I am willing to buy new parts if needed, I just don't want to by parts to fix one end when the other end is the problem
  #5 (permalink)
Old 01-21-2010, 02:03 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Do the tranny coupler test in my sticky "replacing direct drive washer brake shoes" and post results.
__________________
  #6 (permalink)
Old 01-24-2010, 03:35 PM
Junior Member
Default
Thanks for replying. I did some more work. I totally disassembled the washer and cleaned everything. All the parts came out. Motor, trans, drive tube, drum, lint filter,outer drum - everything. I lightly greased all of the friction points and worked the brake over. I sanded the shoes and drum and verified the brake action when the cam was rotated. The clutch is new, I made sure the spring was similar to the old one. I pulled the lint filter out and cleaned it. Of course the drum was out and I cleaned the outer tank. No sign off foreign objects or rubbing anywhere. I reassembled and made sure the drive block was installed correctly and that everything was tight. All off the parts look like new. No rust or corrosion anywhere. all of the plastic parts are intact and seem to be in good shape. The drive coupler is good and tight.
Now the bad news. We ran a couple of loads and it seemed to spin up the way it should. BUT, while I was watching the last load, I notice when it went from the rinse cycle to the spin cycle, it didn't sound right. I slipped a screw driver into the door switch and opened the lid. The drum was not turning. The motor was humming quietly but no spin. I released the door switch and re activated it and the drum took off. I noticed when it works right you hear a clunk when it engages. I don't hear the clunk when it stalls.
The scenario goes : rinse - timer times out - drum slows to stop -timer switches to spin - clunk sound - motor and drum winds up -all is good. If I don't hear that clunk, I can be sure it isn't spinning. I can set the washer on spin and work the door switch and get it to repeat the failure, although random stalling. When it does stall, I release the door switch and poke it down again and it normally takes off.
I would like to say that everything I looked at looks in great shape. But what is the hang up? door switch maybe?
  #7 (permalink)
Old 01-25-2010, 01:15 AM
Senior Expert
APP Volunteer
Default
When the spin basket stops and the motor is running, check the clutch housing above the tranny, is it spinning?
__________________
  #8 (permalink)
Old 01-25-2010, 05:15 PM
Junior Member
Default
Wow Richappy - your up late!
I guess the only way to observe what you suggest is to remove the cabinet and run the washer? As this is intermittent, I would possible have to run it bare bones for possible a week or two - hopefully less. Is that possible? Is there anything I would have to improvise to run it like that? It wouldn't be a problem for me, my wife and I are the only two that would go near it. Proper safety considerations would be followed.
  #9 (permalink)
Old 01-26-2010, 01:32 AM
Senior Expert
APP Volunteer
Default
If it is the clutch, it will slip more with a heavy load.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool washer spin problem amtnlvr Washer Repair 1 02-17-2010 05:57 PM
Replaced clutch--machine noisier mustech Washer Repair 1 11-06-2009 10:45 AM
Whirlpool Washer Spin Problem JDK0806 Washer Repair 5 09-26-2009 08:28 PM
Washer won't spin...bad clutch? RobertC Washer Repair 6 07-11-2008 02:34 AM
New clutch and basket drive - still no spin jbrad4ou Washer Repair 9 05-09-2008 03:47 AM
