Discuss
Intermitent LF on whirlpool Calypso Washer
 in
Washer Repair
Our Whirlpool Calypso washer will give an LF code intemitantly. This only happens on the rinse cycle and it will
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Intermitent LF on whirlpool Calypso Washer
  #1 (permalink)
Old 01-16-2010, 01:43 PM
Junior Member
troubledinTX is on a distinguished road
Unhappy Intermitent LF on whirlpool Calypso Washer
Model Number: GVW9959K   Brand: Whirlpool   Age: 5 - 10 years
Our Whirlpool Calypso washer will give an LF code intemitantly. This only happens on the rinse cycle and it will always happen before the fabric softener is released. What could be the cause and how do I repair it.
Related Models
Whirlpool GVW9959KL0 WASHER
Whirlpool GVW9959KL1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL3 AUTOMATIC WASHER
Whirlpool GVW9959KQ0 WASHER
Whirlpool GVW9959KQ1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ3 AUTOMATIC WASHER
Whirlpool GVW9959KT0 WASHER
Whirlpool GVW9959KT1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT3 AUTOMATIC WASHER
Maytag GW18F1A WASHER-TOP LOADING
Maytag GW18F1H WASHER-TOP LOADING
Maytag GW18F1W WASHER-TOP LOADING
Maytag GW18F2A WASHER-TOP LOADING
Maytag GW18F2H WASHER-TOP LOADING
Maytag GW18F2W WASHER-TOP LOADING
Maytag GW18G1A WASHER-TOP LOADING
Maytag GW18G1HW WASHER-TOP LOADING
Maytag GW18G1WW WASHER-TOP LOADING
Maytag GW20F6A WASHER-TOP LOADING
Maytag GW20F6H WASHER-TOP LOADING
Maytag GW20F6W WASHER-TOP LOADING
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0 GAS RANGE
Whirlpool GW395LEGB1 GAS RANGE
Whirlpool GW395LEGB2 GAS RANGE
Whirlpool GW395LEGB3 GAS RANGE
Whirlpool GW395LEGB4 GAS RANGE
Whirlpool GW395LEGB5 GAS RANGE
Whirlpool GW395LEGB6 GAS RANGE
Whirlpool GW395LEGQ0 GAS RANGE
Whirlpool GW395LEGQ1 GAS RANGE
Whirlpool GW395LEGQ2 GAS RANGE
Whirlpool GW395LEGQ3 GAS RANGE
Whirlpool GW395LEGQ4 GAS RANGE
Whirlpool GW395LEGQ5 GAS RANGE
Whirlpool GW395LEGQ6 GAS RANGE
Whirlpool GW395LEGT2 GAS RANGE
Whirlpool GW395LEGT3 GAS RANGE
Whirlpool GW395LEGT4 GAS RANGE
Whirlpool GW395LEGT5 GAS RANGE
Whirlpool GW395LEGT6 GAS RANGE
Whirlpool GW395LEGZ0 GAS RANGE
Whirlpool GW395LEGZ1 GAS RANGE
Whirlpool GW395LEGZ2 GAS RANGE
Whirlpool GW395LEGZ3 GAS RANGE
Whirlpool GW395LEPB00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW397LXUB0 30" Gas Slide-In
Whirlpool GW397LXUB05 30" GAS SLIDE-IN
Whirlpool GW397LXUB06 30" GAS SLIDE-IN RANGE
Whirlpool GW397LXUB1 30" GAS SLIDE-IN
Whirlpool GW397LXUB5 30" GAS SLIDE-IN
Whirlpool GW397LXUQ0 30" Gas Slide-In
Whirlpool GW397LXUQ06 30" GAS SLIDE-IN
Whirlpool GW397LXUQ1 30" GAS SLIDE-IN
Whirlpool GW397LXUQ6 30" GAS SLIDE-IN
Whirlpool GW397LXUS0 30" Gas Slide-In
Whirlpool GW397LXUS05 30" GAS SLIDE-IN
Whirlpool GW397LXUS06 30" GAS SLIDE-IN RANGE
Whirlpool GW397LXUS1 30" GAS SLIDE-IN
Whirlpool GW397LXUS5 30" GAS SLIDE-IN
Whirlpool GW397LXUT0 30" Gas Slide-In
Whirlpool GW397LXUT05 30" GAS SLIDE-IN
Whirlpool GW397LXUT06 30" GAS SLIDE-IN
Whirlpool GW397LXUT1 30" GAS SLIDE-IN
Whirlpool GW397LXUT5 30" GAS SLIDE-IN
Whirlpool GW399LXUB0 30" Gas Slide-In
Whirlpool GW399LXUB05 30" GAS SLIDE-IN
Whirlpool GW399LXUB06 30" GAS SLIDE-IN RANGE
Whirlpool GW399LXUB1 30" Gas Slide-In
Whirlpool GW399LXUB5 30" Gas Slide-In
Whirlpool GW399LXUQ0 30" Gas Slide-In
Whirlpool GW399LXUQ06 30" GAS SLIDE-IN
Whirlpool GW399LXUQ1 30" Gas Slide-In
Whirlpool GW399LXUQ6 30" Gas Slide-In
Whirlpool GW399LXUS0 30" Gas Slide-In
Whirlpool GW399LXUS04 30" GAS SLIDE-IN
Whirlpool GW399LXUS05 30" GAS SLIDE-IN
Whirlpool GW399LXUS06 30" GAS SLIDE-IN RANGE
Whirlpool GW399LXUS1 30" Gas Slide-In
Whirlpool GW399LXUS4 30" GAS SLIDE-IN
General Electric GWE23LBTBFSS REFRIGERATOR T SERIES
General Electric GWE23LGTIFSS REFRIGERATOR T SERIES
General Electric GWE23LGTJFSS REFRIGERATOR T SERIES
General Electric GWE23LGYAFSS REFRIGERATOR Y SERIES
 GWHD6500R Air Conditioner
General Electric GWR03AAMABB Refrigerator
General Electric GWRE6270H0WW WASHER
General Electric GWRE6270H1WW WASHER
General Electric GWRE6270H2WW WASHER
General Electric GWRE6270K0WW WASHER
General Electric GWRE6270K2WW WASHER
  #2 (permalink)
Old 01-18-2010, 11:43 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
It is possible your line through the fabric softener dispenser is partially obstructed, giving the LF error which means it is taking too long to fill. I would try cleaning out all of the dispenser lines, and if that does not fix things then you may need to replace the inlet valve assembly which may not be working correctly.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Calypso Washer - There is power, but does not respond to any commands dtdiep Washer Repair 8 01-18-2011 06:20 AM
whirlpool calypso mbeal Washer Repair 1 01-28-2010 04:59 PM
Whirlpool Intermitent Pump operation Whale215 Dishwasher Repair 10 09-24-2009 11:53 AM
Whirlpool Calypso rivera Washer Repair 0 10-16-2007 01:46 PM
Whirlpool Calypso error shola Washer Repair 0 07-30-2007 10:43 AM
