Well, we noticed that the clothes were coming out of our washer still wet when wash cycle completes. After a little checking I've found:
* The washer appears to run other cycles correctly * The washer appears to be draining properly * Agitation appears to function properly * If you unload the washer, set to spin, it starts slowly but will spin, speed seems a little slower than it should be though * You can hear the motor running as it would normally in all cycles * Washer stops normally if you release the lid switch
When the tub does start to spin, you can apply relatively light pressure and stop the tub. With a load of clothes it does not seem to spin at all or spins very slowly. I have seen posts here suggesting that this could be a problem with the drive block but I have not seen anything suggesting what to look for when inspecting it.
So, my questions are thus:
Does this sound like the drive block?
What should I look for on a drive block to determine if it is my issue?
What should I check next?
