Hi there!
My washing machine doesn't spin dry my clothes anymore. It seems to go through all the cycles just fine, except the spin cycle. But... sometimes it does spin (very, very rarely). When it does, it is because I am fiddling with the cycle button, and I hear clicks (as if the machine is coming in and out of the cycle). It clicks, and starts spinning, clicks and stops spinning, clicks again restarts spinning, but only if I am holding the cycle button a certain way. Is it a problem with the wireing? It seems the machine doesn't recognize it is in the spin cycle, as if it is a problem with the activator...
Help! Can I fix this myself?
If you will post a model number so we can see exactly what machine you have someone may be able to help you.
