Discuss
Maytag sav3655aww
 in
Washer Repair
Maytag washer wont agitate. It spins fine and pumps out water. The belt was damaged in 2 spots. Put a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag sav3655aww
  #1 (permalink)
Old 01-14-2010, 05:13 PM
Junior Member
mamagraham is on a distinguished road
Default Maytag sav3655aww
Model Number: sav3655aww   Brand: Maytag   Age: 1 - 5 years
Maytag washer wont agitate. It spins fine and pumps out water. The belt was damaged in 2 spots. Put a new belt on, still the same. The motor, pulleys and trans seem to be working proper. We can meve it by hand and ran it for a visual. Removed the agitator and everything looks good except a lot of dirt build up. We can not move the tub freely at this time but maybe we shut it off mid cycle in all this testing. Husband can get it to turn with a good yank. Could it be a stuck brake? Where is it? Or maybe a bearing. I've read posting for 2 days on a dozen sites. Need help!
Ads By Google
Related Models
Maytag SAV3655AWW Washer - Top Loading
Maytag SAV365AAWW Washer - Top Loading
Maytag SAV365AAWx Washer - Top Loading
Maytag SAV365ZAWW Washer - Top Loading
Maytag SAV3710AWW Washer - Top Loading
Maytag SAV405DAWW Washer - Top Loading
Maytag SAV405DEWW Washer - Top Loading
Maytag SAV4655AWQ Washer - Top Loading
Maytag SAV4655AWW Washer - Top Loading
Maytag SAV4655EWQ Washer - Top Loading
Maytag SAV4655EWW Washer - Top Loading
Maytag SAV4710AWW Washer - Top Loading
Maytag SAV505DAWQ Washer - Top Loading
Maytag SAV505DAWW Washer - Top Loading
Maytag SAV515DAWW Washer - Top Loading
Maytag SAV515DEWW Washer - Top Loading
Maytag SAV5300AWW Washer - Top Loading
Maytag SAV5401AWQ Washer - Top Loading
Maytag SAV5401AWW Washer - Top Loading
Maytag SAV5600AWW Washer - Top Loading
Maytag SAV5701AWQ Washer - Top Loading
Maytag SAV5701AWW Washer - Top Loading
Maytag SAV5710AWW Washer - Top Loading
Maytag SAV571EEWW Washer - Top Loading
Maytag SAV5910AWW Washer - Top Loading
Maytag SAV5910EWW Washer - Top Loading
Maytag SAW25K3S Washer - Top Loading
Whirlpool SAWB600HQ0
Whirlpool SAWB600JQ0
Whirlpool SAWB600JQ1
Whirlpool SAWS800HQ0
Whirlpool SAWS800JQ0
Whirlpool SAWS800JQ1
Whirlpool SAWS800JQ2
Whirlpool SAWS800MQ0 Automatic Washer
Whirlpool SAWS900HQ0
Whirlpool SAWS900JQ0
Whirlpool SAWS900MQ0 Automatic Washer
Whirlpool SAWX650JQ0
Whirlpool SAWX650MQ0 Automatic Washer
Whirlpool SAWX650MQ2 Automatic Washer
Whirlpool SB1000SKN0
Whirlpool SB100PEDB0
Whirlpool SB100PEDB1
Whirlpool SB100PEDB2
Whirlpool SB100PEDB4
Whirlpool SB100PEDB5
Whirlpool SB100PEK0
Whirlpool SB100PEK1
Whirlpool SB100PER0
Whirlpool SB100PES0
Whirlpool SB100PES1
Whirlpool SB100PES2
Whirlpool SB100PES3
Whirlpool SB100PES4
Whirlpool SB100PSK0
Whirlpool SB100PSK1
Whirlpool SB100PSR0
Whirlpool SB100PSR1
Whirlpool SB130PEDB0
Whirlpool SB130PEDB1
Whirlpool SB130PEDB2
Whirlpool SB130PEK0
Whirlpool SB130PER1
Whirlpool SB130PER2
Whirlpool SB130PER3
Whirlpool SB130PER4
Whirlpool SB130PER5
Whirlpool SB130PERW0
Whirlpool SB130PSK0
Whirlpool SB160PEDB0
Whirlpool SB160PEDB1
Whirlpool SB160PEDB2
Whirlpool SB160PEDB4
Whirlpool SB160PEDQ0
Whirlpool SB160PEDQ1
Whirlpool SB160PEDQ2
Whirlpool SB160PEDQ4
Whirlpool SB160PEEB1
Whirlpool SB160PEEB2
Whirlpool SB160PEEB5 24" Built - in - Oven Gas
Whirlpool SB160PEEB6
Whirlpool SB160PEEB7
Whirlpool SB160PEEB8
Whirlpool SB160PEEB9
Whirlpool SB160PEEQ1
Whirlpool SB160PEEQ2
Whirlpool SB160PEEQ5 24" Built - in - Oven Gas
Whirlpool SB160PEEQ6
Whirlpool SB160PEEQ7
Whirlpool SB160PEEQ8
Whirlpool SB160PEEQ9
Whirlpool SB160PEXB0
Whirlpool SB160PEXB1
Whirlpool SB160PEXQ0
Whirlpool SB160PEXQ1
Amana SB21VE Ref - SXS/I&W
Amana SB21VPSE Ref - SXS/I&W
Amana SB21VW Ref - SXS/I&W
Thermador SB2B
Amana SB520K Ref - SXS/I&W
Amana SB520SW Ref - SXS/I&W
Amana SB520TW Ref - SXS/I&W
Amana SBC24FX0 Range - Electric Std Delaware
Amana SBC24FX5 Range - Electric Std Delaware
Amana SBC24FXOW Range - Electric Std Delaware
Amana SBC26CK Range - Electric Std Delaware
Amana SBD20H Ref - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K Ref - SXS/I&W
Amana SBD20M Ref - SXS/I&W
Amana SBD20MW Ref - SXS/I&W
Amana SBD20NE Ref - SXS/I&W
Amana SBD20NW Ref - SXS/I&W
  #2 (permalink)
Old 01-16-2010, 06:28 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I suspect the problem is in your transmission. If the motor will run with the belt off in agitate mode then the transmission is likely the problem. The brake could be an issue, but only if there is a mechanical breakdown of it.
Here is a service manual for your machine.
http://www.servicematters.com/maytag...s/16022937.pdf
__________________
  #3 (permalink)
Old 01-17-2010, 07:31 AM
Junior Member
Default
I figured as much, thanks for the manual. I found a used nonoperating washer for parts on Craigslist for less than a used transmission ($50). Is there a way I can test it before I buy it to make sure it works? The seller does not seem to know what the problem is except that it cost $80 to fix. I am inclined not to bother with them as I can't seem to get a direct answer as to it's mechanical issue. A reputable repair shop may have one hand and is closer but closed till Monday, maybe better to wait.
  #4 (permalink)
Old 01-17-2010, 07:55 AM
Senior Expert
APP Volunteer
Default
I am not a fan of used mechanical parts in general and used transmissions in particular, and would strongly suggest that if you want to minimize your cost and maximize the liklihood of success that take the money and put it into a used Whirlpool/Kenmore/Roper direct drive top loading machine.
In our area you can get a very good used machine on Craig's List for about $100 to $150, usually towards the lower end. We also have a Habitat for Humanity Home Store that sells used appliances in that price range (I test and repair for them on a volunteer basis so I am biased, so take that into account).
These machines will do a great job on your clothes, last a long time and if they need repairing it is easy to do and the parts are inexpensive.
__________________
  #5 (permalink)
Old 01-20-2010, 03:08 PM
Junior Member
Default
I took it to a repair tech that would said it was probably a bearing. Turns out it is the transmission and now he does not have a new or used one. Looking at $300 into parts and labor. Called Local Maytag Dealer and found out it is under 10 year warranty, Yea. I just have to pay for service and labor. The unfair thing is the Maytag repair shop says other parts need to be replaced as part of a new tranny job, totalling cost of new trans, other guy did not. What do you know about this? They said the belt and a bearing that runs $125. Maybe a thrust bearing. I just put a new belt on it the day before I took it in so I doubt that, and the guy who has it said the bearings are good. What's you opinion?
  #6 (permalink)
Old 01-20-2010, 04:22 PM
Senior Expert
APP Volunteer
Default
Yes, that work probably should be done, except the belt which the repair tech probably did not know was new. Those parts, see this tech bulletin on the bearing and seal
http://www.servicematters.com/maytag...TDL-0060-B.pdf
will fail and you don't want to spend all that money on the labor for the transmission and put old, worn parts back in. The labor is already paid for so it is not a bad del. The reason it costs so much is that Maytag has a large mark up on parts, as you can see if you search for the parts on this site.
That being said I stick with my original position. Put the money in a good new or used washer, a no frills top loading one and you should be much happier.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
