Discuss
will not spin
 in
Washer Repair
This my first post...hope it works. My problem is as follows: Washer will fill, washer will agitate, washer will
Appliance Repair Forum > Appliance Repair Help > Washer Repair » will not spin
  #1 (permalink)
Old 04-03-2008, 04:14 PM
tdavis184 tdavis184 is offline
Junior Member
tdavis184 is on a distinguished road
Default will not spin
Model Number: 70 series 110.20702   Brand: Kenmore   Age: 5 - 10 years
Washer will fill, washer will agitate, washer will pump out, washer will fill for rinse, washer will pump out, then it will not spin...it just sits there making the correct noise but the tub is not spinning. I can raise the lid and then shut it and it will spin normally. If I do not catch this part of the cycle in time and come back after the cycle has completely stopped...I can turn the timer to spin, raise and lower the lid and it will spin correctly. I have replaced the lid switch.
Is the problem the coupler?
Summary: Cycle works fine til the point of spinning...no spin til you open and closed the lid. Problem is on all cycle types...ie. regular, delicates, perm press.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-04-2008, 04:25 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem with your washer is a bad timer.
- The part number for the timer is AP3114923
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 04-04-2008, 07:32 PM
Junior Member
Default Thanks Gene!!
Even though raising and lowering the lid will cause the washer to spin correctly, your best bet is still the timer? While the washer is in the spin mode with the motor running, I can walk over and raise and lower the lid and it will then start to spin and finish out correctly. Your expertise denotes timer. Thanks.
  #4 (permalink)
Old 04-04-2008, 08:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Due to your washer has a neutral drain transmission, it should stop for a few seconds during the drain to engage the spin. This stop interval operates by timer, that's why the timer has to be replaced.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will not spin during spin cycle Nathaniel Washer Repair 4 01-30-2008 07:35 AM
Final spin cycle doesn't spin gr8fulbear@yahoo.com Washer Repair 9 01-30-2008 05:01 AM
washer won't spin in final spin cycle amie48 Washer Repair 0 01-12-2008 01:59 PM
Washer will not spin on spin cycle bellboy Washer Repair 0 11-11-2007 09:16 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
