| » water fill cycle wont stop |
Model Number: ras6233kq1 Brand: Roper Age: 5 - 10 years
washer has been stored in an unheated area under freezing weather. when starting washer, water fill cycle wont shut off. what should i check first, and where is it located
If the water will not shut off when you shut off the machine, the water valve is probably the problem; if it will shut off when you shut off the machine the water level control is the problem.
If the water level control is not working, make sure the tube from the water level switch to the tub is clear and unbroken (it may still be filled with ice and that is your problem) If it is ok, try replacing the water level switch. You can get to the parts by taking off the cabinet. This site will illustrate how. Kenmore top loader blues (SublimeMasterJW's Appliance Advice) Your machine, like the Kenmore is a Whirlpool made direct drive model.
__________________
| Display Modes | |
| Wont Fill With Water | rvt2004 | Washer Repair | 1 | 11-06-2009 11:00 AM |
| Wont Fill With Water | rvt2004 | Washer Repair | 0 | 11-04-2009 07:11 PM |
| Dishwasher Wont Fill Durring Second Cycle | RICKCARDO | Dishwasher Repair | 1 | 09-14-2009 03:45 AM |
| washing machine wont fill on second cycle | nature | Dishwasher Repair | 0 | 06-29-2009 12:58 PM |
| Dryer wont stop cycle automatically runs continously | MrSchlimmer | Dryer Repair | 1 | 10-31-2007 03:43 AM |
