Discuss
Washer is "dancing" more these days
 in
Washer Repair
Hello all, My (almost) 4 year old Maytag seems to be "dancing" more these days and I can'
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer is "dancing" more these days
  #1 (permalink)
Old 04-02-2008, 04:11 PM
gustavio gustavio is offline
Junior Member
gustavio is on a distinguished road
Default Washer is "dancing" more these days
Model Number: SAV205DAWW   Brand: Maytag   Age: 1 - 5 years
Hello all,
My (almost) 4 year old Maytag seems to be "dancing" more these days and I can't seem to pinpoint a reason why. My wife and I are aware of the need to balance each load to prevent this; however, it just happens more often recently. So, upon investigation, the first thing I did was to check to ensure the washer is perfectly level and it is OK. However, I did notice one possible issue; in that, the water tub feels "tight" when there is no water in the washer and feels "loose or wobbly" when the tub is full of water. Could this be the root cause of the dancing problem or is this just a normal condition? Any advice on correcting this issue would be greatly appreciated.
Best regards,
gus
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-03-2008, 01:48 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Gus,
Remove the front panel and check that the suspension springs are attached to the base and outer tub. Check the belt.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 04-03-2008, 02:11 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Also, look for white shavings under the transmission.
__________________
  #4 (permalink)
Old 04-03-2008, 08:53 PM
Junior Member
Default Update on my problem
Hello Gene and Richappy,
Thanks for the tips but I think I'm going to hold off on any attempted repair for a while because I placed all 4 legs in rubber furniture stops and that seemed to fix the dancing routine (the original washer footing was metal and was sliding all over the floor... very easily, I might add).
However, I did find the same problem posted elswhere and if that turns out to be my problem as well, I'm just going to get a new washer but this time, I'm going to go for a cheap Kenmore.
FYI, here's the post:
"When the machine was just under 3 years old, it began to get out of balance frequently and became very noisy. Within a month of these symptoms, grease starting appearing on my clothes. A week later, unit started leaking. Called for repair and found out that the triple seal and bearings had failed. As a result the parts around the transmission had rusted and corroded. Total repair estimate: $410! Called for a second estimate: $390."
Now, in your expert opinions, could I be looking at the same thing in a month or two?
Thanks again,
gus
  #5 (permalink)
Old 04-04-2008, 08:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Gus,
If I new an answer I would probably have more money than Bill Gates has.
__________________
  #6 (permalink)
Old 04-04-2008, 11:00 PM
Senior Expert
APP Volunteer
Default
Your SAV washer is a better washer than say a Performa which is really junk if it is less than a few years old. The other washer may have been a Performa.
__________________
  #7 (permalink)
Old 04-05-2008, 05:35 AM
Junior Member
Default
Thanks again Gene and richappy,
I really apprecitae you both taking the time to respond.
Best regards,
gus
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
A "how to" on repairing a maytag atlantis washer vincom Washer Repair 1 01-25-2008 06:54 AM
Washer makes "CLUNKING" noise after spin cycle. apetty Washer Repair 3 01-22-2008 02:33 PM
Kenmore (Whirlpool) washer "bang" noise when spinning dadasmatta Washer Repair 2 12-22-2007 08:34 PM
Older Kenmore washer appears "dead"! Cappy Washer Repair 0 10-27-2007 08:18 PM
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
