during spin cycle washer makes a rubbing sound also hear it when washer stops. Thanks
Thanks I'll take a look when I get home
Removed front and put machine on spin no rubbing waited to do a large load again no no noise doing a small load now and there is some rubbing I'll check on how to center . Thanks
I had same problem when people move them they use a freight dolly and push the bottom of washer up and when you put a load in the pully hits the bottom of washer. (look at the ribs on bottom of washer with front off and you will probably find your problem)
