Discuss
removing agitator
 in
Washer Repair
how do you remove the agitator to service the transmission tube seal on this model
Appliance Repair Forum > Appliance Repair Help > Washer Repair » removing agitator
  #1 (permalink)
Old 04-01-2008, 04:48 PM
george m george m is offline
Junior Member
george m is on a distinguished road
Question removing agitator
Model Number: awm452   Brand: Speed Queen   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-01-2008, 05:04 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
There should be a bolt under the cap at the top of the agitator, after you get that off grab the bottom of the agitator and pull off. If it is stuck, put a rope under the agitator and pry it out with a 2x4 with the top of the washer as a pry point.
Go to web site www.applianceaid.com for info on this, this is a big job and I have declined to fix these!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore washer 80 top agitator does not move with bottom agitator erbaker Washer Repair 1 02-19-2008 12:11 PM
Removing Dogs From Agitator on Ultracare II laundrysucks Washer Repair 0 02-09-2008 03:25 PM
Removing Agitator bubbatippy Washer Repair 1 01-24-2008 02:18 PM
Removing the upper agitator bolt pcntexas Washer Repair 3 12-10-2007 08:21 PM
Removing the cam inside the agitator. AnnM Washer Repair 1 11-19-2007 08:08 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
