My GE washer will go through wash cycle,pump out water & refill for rinse,but willnot pump out water and final spin,can anyone help!!!!
This machine has some of the most complex electronics ever built into a washer, and a washer is no place for complex electronics. The problem is likely in the main control board or the inverter. Unfortunately GE does not let tech info about its machine out. Fortunately the nice folks at this site have a manual posted which will show you how to do some testing, and I am sure they will not mind if we link to it. Here it is http://appliancejunk.com/ge/washer/31-9103.pdf
