Hello, I am replacing the tub gasket on a G.E. WH08X10036 front loading washing machine. I was able to remove the old one without taking off the front panel. the dryer is mounted on top of the washer and cannot be removed. is it possible to remove the front panel with the dryer on top ? if not do you have any suggestions how i should install the new gasket. thankyou.........Rick
I cannot get your model number to come up, so can you check it and repost if it is not correct.
Originally Posted by: sidfink43 I cannot get your model number to come up, so can you check it and repost if it is not correct.
Thanks this is the modle number WH08X10036 THANKYOU.....RICK
