| » Maytag Washer does not agitate or spin |
Model Number: LAT5914AAE Brand: Maytag Age: More than 10 years
Hi. I have a Maytag Washer MODEL #LAT5914AAE that I can hear (click) and see the dial go through the different cycles, but yet does nothing. I would like to fix it, but not sure if it is worth the time/money. It is at least 15 years old. Does anyone know if it is something simple?
Thanks in advance. Ads By Google Related Models |
There is a fuse that may be blown. If it is blown I recommend replacing the entire lid switch assembly because most of the time one of the other switches causes that fuse to blow. To access the fuse remove the cover off the back of the control panel. Hope this helps!
Clothes Washer Repair Guide |
After reviewing your wiring diagram I believe your problem is in the water level control or the timer. It is possible the motor is bad or there is a loose connection but more than likely one of these two things.
If you have an ohmmeter you can check the water level control. Disconnect power and disconnect the wires from the control. Then test for continuity from the number 7 terminal to the number 15 terminal. With the tub empty there should be continuity and it should be open from 7 to 16. With the tub full it should be to opposite. I have seen a lot of problems with the timers on this model. |
| Display Modes | |
| Maytag washer wont spin or agitate | peiboy | Washer Repair | 8 | 04-01-2013 04:11 AM |
| maytag fills doesn't agitate spin etc | vanlisa | Washer Repair | 3 | 12-28-2010 12:57 PM |
| Maytag washer won't fill or agitate, but will spin | spitz72 | Washer Repair | 1 | 11-26-2009 07:35 AM |
| maytag washer will fill with water, but not agitate or spin | welliott | Washer Repair | 1 | 11-24-2009 06:55 PM |
| Maytag Washer will not agitate but will spin and rinse | pkbeckman | Washer Repair | 3 | 02-24-2009 02:36 PM |
