Discuss
Whirlpool Does Not Rinse During Spin Cycle
 in
Washer Repair
Ok.... We are mechanically inclined and can not afford a new Washer... so... What do I do first? The washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Does Not Rinse During Spin Cycle
  #1 (permalink)
Old 01-10-2010, 01:35 PM
Junior Member
Ladycarr is on a distinguished road
Default Whirlpool Does Not Rinse During Spin Cycle
Model Number: LA7800XSWO   Brand: Whirlpool   Age: More than 10 years
The washer is doing everything except spraying water into the spinning tub when it is rinsing. I wish I had noticed years ago if it comes from the same source as the fill line.
I have dogs and cats and sometimes a lot of dog hair can end up in the wash. So... First I check to see if the line is clogged??? It is not spilling out onto the flore. I can hear the ticking sound it usually makes just not spray. Also, I have unplugged it for 30 seconds and tried again and it is still broken. I am about to start pouring water on to the clothes myself during the spin cycle....
Do these Washers have computers modules or something... It has been terrific washer. I will try to print the diagrams found on this web site to begin to take it apart.
Thank you for your help! Wishing you the best!
Ads By Google
Related Models
Whirlpool LA7800XTF0 AUTOMATIC WASHER
Whirlpool LA7800XTF1 AUTOMATIC WASHER
Whirlpool LA7800XTG0 AUTOMATIC WASHER
Whirlpool LA7800XTG1 AUTOMATIC WASHER
Whirlpool LA7800XTM0 AUTOMATIC WASHER
Whirlpool LA7800XTM1 AUTOMATIC WASHER
Whirlpool LA7800XTN0 AUTOMATIC WASHER
Whirlpool LA7800XTN1 AUTOMATIC WASHER
Whirlpool LA7800XTW0
Whirlpool LA7800XTW1
Whirlpool LA7801XTF0
Whirlpool LA7801XTG0
Whirlpool LA7801XTM0
Whirlpool LA7801XTN0
Whirlpool LA7801XTW0
Whirlpool LA7899XPW3
Whirlpool LA7900XPW1
Whirlpool LA7900XSW0
Whirlpool LA7900XSW1
Whirlpool LA7900XSW2
Whirlpool LA7900XTF0
Whirlpool LA7900XTG0
Whirlpool LA7900XTG1
Whirlpool LA7900XTM0
Whirlpool LA7900XTN0
Whirlpool LA7900XTN1
Whirlpool LA7900XTW0
Whirlpool LA7900XTW1
Whirlpool LA7980XSW0
Frigidaire LA800AXD1 Wwh(v2) / 27 " Washer
Frigidaire LA800AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA800AXW1 Wwh(v1) / 27 " Washer
Frigidaire LA800AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA800JXD4 Wwh(v1) / Washer
Frigidaire LA800JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA800JXF4 Wwh(v2) / Washer
Frigidaire LA800JXH4 Wwh(v3) / Washer
Frigidaire LA800JXH5 Wwh(v2) / Top Load Washer
Frigidaire LA800JXV4 Wwh(v4) / Washer
Frigidaire LA800JXW4 Wwh(v5) / Washer
Frigidaire LA800JXW5 Wwh(v3) / Top Load Washer
Frigidaire LA800MXD1 Wwh(v9) / 27 " Washer
Frigidaire LA800MXD2 Wwh(v9) / 27 " Washer
Frigidaire LA800MXH1 Wwh(v8) / 27 " Washer
Frigidaire LA800MXH2 Wwh(v8) / 27 " Washer
Frigidaire LA800MXW1 Wwh(v7) / 27 " Washer
Frigidaire LA800MXW2 Wwh(v7) / 27 " Washer
Maytag LA806 WASHER-TOP LOADING
Maytag LA806S WASHER-TOP LOADING
Maytag LA810 WASHER-TOP LOADING
Maytag LA8100 WASHER-TOP LOADING
Whirlpool LA8100XWW0
Whirlpool LA8100XWW1
Maytag LA8120 WASHER-TOP LOADING
Maytag LA8140 WASHER-TOP LOADING
Maytag LA8200 WASHER-TOP LOADING
Whirlpool LA8200XWW0
Whirlpool LA8200XWW1
Maytag LA8210 WASHER-TOP LOADING
Maytag LA8240 WASHER-TOP LOADING
Maytag LA8340 WASHER-TOP LOADING
Amana LA83830.A MWAVE - FAMILY SIZE (60 HZ)
Whirlpool LA8400XWF0
Whirlpool LA8400XWF1
Whirlpool LA8400XWG0
Whirlpool LA8400XWG1
Whirlpool LA8400XWM0
Whirlpool LA8400XWM1
Whirlpool LA8400XWN0
Whirlpool LA8400XWN1
Whirlpool LA8400XWW0
Whirlpool LA8400XWW1
Maytag LA8420 WASHER-TOP LOADING
Maytag LA8440 WASHER-TOP LOADING
Maytag LA8500 WASHER-TOP LOADING
Maytag LA8520 WASHER-TOP LOADING
Whirlpool LA8580XWF0
Whirlpool LA8580XWF1
Whirlpool LA8580XWF2
Whirlpool LA8580XWG0
Whirlpool LA8580XWG1
Whirlpool LA8580XWG2
Whirlpool LA8580XWM0
Whirlpool LA8580XWM1
Whirlpool LA8580XWM2
Whirlpool LA8580XWN0
Whirlpool LA8580XWN1
Whirlpool LA8580XWN2
Whirlpool LA8580XWW0
Whirlpool LA8580XWW1
Whirlpool LA8580XWW2
Maytag LA8600 WASHER-TOP LOADING
Maytag LA8640 WASHER-TOP LOADING
Maytag LA8650 WASHER-TOP LOADING
Maytag LA8700 WASHER-TOP LOADING
Maytag LA8740 WASHER-TOP LOADING
Maytag LA8800 WASHER-TOP LOADING
Whirlpool LA8800XSW0
Whirlpool LA8800XSW1
Whirlpool LA8800XSW2
Whirlpool LA8800XTF0
Whirlpool LA8800XTF1
Whirlpool LA8800XTG0
Whirlpool LA8800XTG1
Whirlpool LA8800XTM0
Whirlpool LA8800XTM1
Whirlpool LA8800XTN0
Whirlpool LA8800XTN1
Whirlpool LA8800XTW0
Whirlpool LA8800XTW1
Maytag LA882 WASHER-TOP LOADING
Maytag LA8820 WASHER-TOP LOADING
Maytag LA883 WASHER-TOP LOADING
Maytag LA884 WASHER-TOP LOADING
Maytag LA8840 WASHER-TOP LOADING
Whirlpool LA8860XWQ0
Whirlpool LA9100XTF0
Whirlpool LA9100XTF1
Whirlpool LA9100XTG0
Whirlpool LA9100XTG1
  #2 (permalink)
Old 01-11-2010, 05:14 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for WHIRLPOOL LA7800XSW0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/w...%203351745.pdf
And a manual which should be useful
https://secured.whirlpool.com/Servic...$FILE/L-55.pdf
Yes it will come from the same place.
They use a mechanical timer
First check that the unit will fill with hot, warm and cold. This tells you that the water temperature switch is OK and both valve are OK.
If OK it sounds like a timer problem.
You could confirm this by unplugging the unit and using a meter to check the timer contacts (do they close when they should) using the timing chart and manually turning the dial.
__________________
  #3 (permalink)
Old 01-14-2010, 10:22 AM
Junior Member
Default Still Working On It
Dear Denmen:
Im still working up to it. I have been trying to wash everthing we will need for the coming week. I am using a hose attached to the hot water heater and a stock pot full of water carefully applied at the first few seconds of the spin cycle. We have been watching the machine in all phases.... like watching water to see it boil .. only boiling water is faster.
Ah.... I did notice that even though I will rinse in this process 4 times I still get soap in the machine. I saw some coming up as the water came up through the little hole in the agitator base. I really need to clean the dog hair out of the lint filter. The problem of no water rinse during spin is still there but the filters must have a cake of soap on them. I almost want to buy the new timer before he takes it apart to check connections that leads to the pump. Something about checking the solenoids?
Now the weekend is almost here and I will not be able to get the part to next week.
Can you tell me how to clean out the inside of the machine?
Thank you for all your help.
Best regards,
Tommy and Jeanie
  #4 (permalink)
Old 01-14-2010, 10:51 AM
Senior Expert
APP Volunteer
Default
Check out page 23 in the manual
__________________
  #5 (permalink)
Old 02-12-2010, 08:54 PM
Junior Member
Default Thank you Denman
Dear Denman:
Again, Thank you. We just replaced the timer and the rinse water sparkled like Waterford Crystals against my soapy clothes. Although I still wish to take the basket out and clean the dog hair or what is holding the soap underneath, my "right arm" argues that there is no filter underneath. Ahhhh.... Well I am grateful it is working well.
"Here is two another 20 Years with my Whirlpool Washer." My god bless her little rusty inner-eds.
Thank you again!
Jeanie
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer won't spin on rinse cycle or high spin bry21317 Washer Repair 10 05-24-2011 12:25 PM
Runs rinse cycle all the way through the spin cycle hebirdseye Washer Repair 2 07-07-2010 10:21 PM
Whirlpool washer loud noise (like a generator) during Rinse & Spin Cycle KM Rahman Washer Repair 1 01-05-2010 05:17 PM
Washer goes to rinse cycle then spin back to rinse, stuck in this mod Pat66 Washer Repair 1 05-08-2009 07:44 AM
Washer will not go through rinse or spin cycle on regular cycle dhilde7165 Washer Repair 0 02-14-2009 04:10 PM
