My washer agitates properly, but it just hums when it is supposed to drain. What should I check for first?
Check the pump for some type of obstruction, maybe a sock or underwear.
If you need more info please post a complete model number.
Originally Posted by: sidfink43 Check the pump for some type of obstruction, maybe a sock or underwear.
If you need more info please post a complete model number. Found a sock in the pump, humming noise from motor
