| » Bosch Washer WFK2401 |
Model Number: WFK2401 Brand: Bosch Age: 5 - 10 years
I have Bosch WFK2401 washer. It is stuck with 1 cycle remaining and the door locked. Nothing is blinking, and the door does not open, even if I turn the power off. If I change the program, it goes through the cycles normally, until 1 cycle remains and then stops. There is no water in the washer. Does anybody know what the problem can be, and at least how to open the door? Thank you
Enter the test program by:
1. Set the cycle knob to any "X" (reset) position 2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button 3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds) The digital display will show 00 for no faults or will show a fault code. To end the test program turn the washer off at any time. Post the results. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
The fault code "06" means "Door open or won't lock". Something wrong with the door lock.
I do not know this model good enough to guide your further. Maybe someone else on the forum can help you better. Gene.
__________________
| Display Modes | |
| Bosch mixer | flakeybunch | General Talk | 1 | 06-13-2008 07:28 PM |
| Bosch WFK2401 moldy smell during operation | GeorgeG | Washer Repair | 3 | 01-20-2008 07:15 PM |
| Bosch washer- leaking at pump assembly | PBroadfoot | Washer Repair | 2 | 01-19-2008 08:57 AM |
| Bosch | memyer | Dishwasher Repair | 2 | 12-19-2007 06:31 AM |
| Bosch Nexxt Premium washer | mdjson@gmail.com | Washer Repair | 1 | 07-24-2007 02:47 PM |
