| » Frigidaire frontloader won't wash/agitate |
Model Number: FWT445GES1 Brand: Frigidaire Age: 5 - 10 years
My Frigidaire Gallery frontloading washer has stopped washing/agitating. It fills with water then sits quietly, though I can hear the timer cycling. After some time it will drain, refill and sit again. Eventually it will spin and rinse.
I have replaced the timer, and it seems to drain okay, although the purging is pretty loud. The discharge strength seems normal into the drain. It acts the same in regular,permanent press, and delicate settings. |
Most likely the problem is a bad motor speed control board (#4 on the cabinet break down diagram).
You have to remove the rear panel to access the part. - The part number for the speed control board is AP2107536 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
I'm glad you were able to fix it.
__________________
| Display Modes | |
| Frigidaire LCE702AWW2 won't spin or agitate | ZoesMom | Washer Repair | 0 | 01-23-2008 06:33 PM |
| Frigidaire Will Not Agitate | Corbie | Washer Repair | 7 | 12-18-2007 07:15 AM |
| Can not select wash cycle - stuck on scrub wash | luke | Dishwasher Repair | 0 | 08-20-2007 09:38 AM |
| whirlpool duet frontloader puet color | desertsilk | Washer Repair | 0 | 07-24-2007 08:25 PM |
| will not agitate | BRAND001 | Washer Repair | 0 | 07-23-2007 07:30 PM |
