| » Washer Won't Agitate But It Spins |
Model Number: WJSR2080V1WW Brand: GE Age: 5 - 10 years
Washer Won't Agitate. It Does Spin And Fill Up The Water. Motor Sounds Like Is Working. Agitator Spins Freely.
How Do I Remove The Agitator To Check The Agitator Coupler? Thanks! |
Quote:
Too funny, it's my same problem! I pulled up on the agitator and it came right up. Now, I'm wondering if the freely-spinning plastic coupler is the culprit. |
If you have a similar GE model the agitator coupler is that plastic cup that attaches the agitator to the tranmission shaft. It has a screw on the top which you will need to remove in order to replace the coupler. The coupler will be around $5 and it protects your transmission so it doesn't break from excesive torque. Hope this helps!
| Display Modes | |
| GE washer sometimes spins sometimes doesn't WJSR2070B2WW | Berto | Washer Repair | 6 | 06-19-2008 08:05 AM |
| Washer spins instead of agitate | garu | Washer Repair | 0 | 03-08-2008 01:06 PM |
| washer some what spins | kent pratt | Washer Repair | 0 | 03-02-2008 04:18 PM |
| Roper Washer spins only | Csugarbrown9122 | Washer Repair | 4 | 01-23-2008 02:39 PM |
| Washer motor spins but will not agitate. | jimmyr | Washer Repair | 1 | 09-19-2007 05:34 AM |
