Front load Frigidaire Washer
Brand: Frigidaire Age: More than 10 years
I bought a door lock assembly part #131888900 and it looked different in the package so I reasd what I could on the enclosed instructions prior to opening it and it appears to be an updated assembley but when I was reading the installation instructions it refers to a red wire in the 9 pin connector that should be in the 2nd position and may need to be moved to the 4th position. There is a red wire however its not in the 2nd position or the 4th position and that other wires dont match the colors on the instructions within that same plug.
Ads By Google
