Discuss
best or cheapest way to fix maytag neptune?
 in
Washer Repair
I have a maytag neptune M# mah3000aww that makes noise like it is coming apart or there is a load
Appliance Repair Forum > Appliance Repair Help > Washer Repair » best or cheapest way to fix maytag neptune?
  #1 (permalink)
Old 03-27-2008, 08:57 AM
Jeffgr8 Jeffgr8 is offline
Junior Member
Jeffgr8 is on a distinguished road
Question best or cheapest way to fix maytag neptune?
Model Number: mah3000aww   Brand: Maytag   Age: More than 10 years
I have a maytag neptune M# mah3000aww that makes noise like it is coming apart or there is a load of bricks in it when it spins everone says it takes a $450.00 part to fix it but why cannt you just replace the baering and not the hole tub?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-27-2008, 06:25 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Maytag does not sell the bearing separate. It comes as a part of the outer tub assembly, that's why it is very expensive.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-28-2008, 06:51 AM
Junior Member
Default
I know maytag wants you to buy the whole tub, but the bearing has to have numbers on it?? like a timken or other number?? I have been a car mechanic and work on large trucks and farm tractors most if not all bearings have a part number on them and can bo found elseware?
  #4 (permalink)
Old 03-29-2008, 04:56 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Crunch into Google, Maytag Neptune MAH3000 spin basket bearings. You will get several sites that will supply bearings. Also, Maytag does sell the seal for them.
Main hard job is pounding out the old bearings, some people use a piece of pipe and a hammer to do it. You can use the old bearings to start pressing in the new ones. I would use a wood dowel to get them in all the way.
Also, when you pull out the spin basket, inspect the spider drum support for water damage, and clean and spray with a good metal protector like rustoleum.
__________________
  #5 (permalink)
Old 03-29-2008, 07:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jeff,
Richappy was right and you probably will find more or less good advise for this bearing over the Internet (you can find everything over the Internet today), but in my opinion this washer is not worth it.
This is very serious job for at least 5 hours (together with the bearing replacement).
I would buy a classic top load washer, made by Whirlpool and without any computers (if you can find a such one).
__________________
  #6 (permalink)
Old 03-31-2008, 08:14 AM
Junior Member
Default
thanks to everyone on the reply's I thought it could be done>>
  #7 (permalink)
Old 03-31-2008, 05:11 PM
Senior Expert
APP Volunteer
Default
If you are going to junk it, remember, it is full of expensive parts. I have one in my junkyard that I will use for parts.
__________________
  #8 (permalink)
Old 04-09-2008, 05:47 PM
Junior Member
Default
I just bought the center support shaft and a tub with bearing that where new for $100.00 How do you get the tub out all the way?
  #9 (permalink)
Old 04-10-2008, 02:19 AM
Senior Expert
APP Volunteer
Default
I believe www.applianceaid.com has this procedure, they say it is rather easy.
__________________
  #10 (permalink)
Old 04-10-2008, 07:57 AM
kellyjo kellyjo is offline
Junior Member
kellyjo is on a distinguished road
Default
I just replaced the bearings on my Nepyune 5500. The bearings were NKS bearings I think. Doesn't matter as they are just common sealed bearings that you can pick up anywhere. You will need to order the seal kit also. I repaired mine for less than $100.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune LR code sonny_p Dishwasher Repair 8 02-29-2008 12:17 PM
Maytag Neptune starts then stops in 5 sec EddieM Washer Repair 3 02-16-2008 10:38 AM
Maytag Neptune washer ccseeley Washer Repair 5 01-31-2008 01:51 PM
Maytag Neptune LarryC Washer Repair 2 09-29-2007 08:56 PM
Maytag Neptune Washer utep42 Washer Repair 1 08-31-2007 04:59 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
