I have an old Maytag washing machine that is not pumping out. Every other part of the cycle seems to be working fine. I have tried all of the normal troubleshooting stuff but no solution to the issue. Ant help would be greatly appreciated. Thanks again, Matt
You say you have triend all of the normal troubleshooting. I assume this means you have checked the belt, the pump and the drain hoses both internal and external.
If you have done this then I have little other suggestions other than replacing the pump. If the drain hoses are clear and the pump is running then it should drain, so replacing the pump would seem logical.
