harleydmb1
#1 Posted : Tuesday, January 5, 2010 12:48:10 PM(UTC)
harleydmb1
When I push on button in nothing is happening. The door is closed tightly, electrical is fine, I hear the timer running.
#2 Posted : Tuesday, January 5, 2010 5:49:26 PM(UTC)
The first thing I would check is the thermal fuse (#7 on the diagram). It has to be checked for continuity and replaced if open. It has to be replaced togehter with the cycling thermostat (#8). Make sure the dryer vent is clean all the way through the vent outlet.
- The thermal fuse Part number: AP3132867
- The cycling thermostat Part number: AP3131939
Here is the Wiring sheet.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LER7646EZ1 | AppliancePartsPros.com
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 Yesterday at 6:43:17 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
Maytag electirc dryer model LDE9334ACM (Dryer Repair)
by Guest 3/22/2024 6:07:19 PM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
Frigidaire Front Load Dryer aeq6000es2 (Dryer Repair)
by Guest 3/3/2024 7:28:15 AM(UTC)
Odd Kenmore Dryer Model number (Dryer Repair)
by adamm53 3/2/2024 3:42:02 PM(UTC)
samsung dryer Dv48H (Dryer Repair)
by Guest 2/27/2024 6:11:07 PM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
