i recently moved and i dropped my washer on its back side and now when i run the washer it leaks all over my floor from the front and back of the pan also when i opened up the cabinet it looks like an oily substance in the bottomwhere do i start fixing this problem?
You should operate it with the front off to see where it is leaking, but I am afraid that you have also damaged the transmission and in doing so damaged the center seal which is causing your leak.
In this case you may want to consider a replacement since other problems may occur even if you spend the money and time to repair this.
