| » My front load washer will not start. push start and nothing happens |
Model Number: GHW9100LW1 Brand: Whirlpool Age: 5 - 10 years
My front loader will not start. the door is shut, has new hinge, locks, has water and power but after I choose the cycle and push start it does nothing.
Take a look at the tech sheet that is either under the top cover or inside the lower service panel. See if you can put the machine in test mode.
Given what you have said I would also check the wiring in the door lock mechanism. It is possible that in replacing the door lock assembly the wiring is loose or not making full connection to the CCU and this is your problem.
__________________
| Display Modes | |
| GE Front Load Washer won't start - model WBVH6240FWW | mejmea | Washer Repair | 14 | 10-25-2010 06:15 PM |
| whirlpol dryer won't start-just hums when I push the start button | bdubois | Dryer Repair | 27 | 02-18-2010 07:36 PM |
| coin washer front load wont start | searsnumberone | Washer Repair | 0 | 09-22-2009 03:04 PM |
| Kenmore Dryer won't start unless PTS (push to start) button depressed and held | trp | Dryer Repair | 1 | 06-07-2009 06:13 AM |
| Washer Makes Strange Noise When I Push Start Button | Kelli Huntsman | Washer Repair | 0 | 01-05-2009 09:28 AM |
