Discuss
washing machine problems
 in
Washer Repair
my washer always seem to run on the same cycle.if you change the cycle to the normal cycle,it still seems
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washing machine problems
  #1 (permalink)
Old 01-04-2010, 11:37 AM
Junior Member
vanmoore1771@yahoo.com is on a distinguished road
Default washing machine problems
Model Number: 11029962891   Brand: Kenmore   Age: 5 - 10 years
my washer always seem to run on the same cycle.if you change the cycle to the normal cycle,it still seems to run on a gentle cycle
Related Models
Kenmore 11029962891 AUTOMATIC WASHER
Kenmore 1103348565 GEARCASE
Kenmore 110357116 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357177 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357970 BASKET DRIVE AND BRAKE ASM
Kenmore 110357972 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358364 BASKET DRIVE AND BRAKE ASM
Kenmore 110358365 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358371 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358483 GEARCASE ASM
Kenmore 110358484 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358485 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358487 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358507 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358795 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358841 GEARCASE AND SUPERSTRUCTURE
Kenmore 110359175 BASKET DRIVE & BRAKE ASM
Kenmore 110359178 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110359279 GEARCASE PARTS
Kenmore 110359517 BASKET DRIVE AND BRAKE PARTS
Kenmore 110359699 BASKET DRIVE AND BRAKE PARTS
Kenmore 110360093 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110360867 DOLE MIXING VALVE ASSEMBLY
Kenmore 110360868 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110362101 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362901 GEARCASE ASM
Kenmore 110363000 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363082 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364443 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364444 BASKET DRIVE AND BRAKE PARTS
Kenmore 110364446 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364494 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365011 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365012 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365014 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365359 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365712 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365859 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366660 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366990 BASKET DRIVE & BRAKE ASM
Kenmore 110367551 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110367593 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 1103733107 KENMORE PORTABLE AUTOMATIC WASHER
Kenmore 110389246 GEARCASE PARTS
Briggs & Stratton 110402-0180-E1 ENGINE
Kenmore 11042182200 AUTOMATIC WASHER
Kenmore 11042182201 AUTOMATIC WASHER
Kenmore 11042722200 AUTOMATIC WASHER
Kenmore 11042722201 AUTOMATIC WASHER
Kenmore 11042822200 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11042822201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042822202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042822203 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042824200 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11042824201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042824202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042824203 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042826200 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11042826201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042832200 AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 11042832201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042834200 AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 11042834201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042836200 AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 11042836201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042922200 WASHER
Kenmore 11042922201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042922202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042922203 RESIDENTIAL WASHER
Kenmore 11042924200 WASHER
Kenmore 11042924201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042924202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042924203 RESIDENTIAL WASHER
Kenmore 11042926200 WASHER
Kenmore 11042926201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042926202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042926203 RESIDENTIAL WASHER
Kenmore 11042932200 WASHER
Kenmore 11042934200 WASHER
Kenmore 11042936200 WASHER
Kenmore 11043902201 WASHER
Kenmore 11043902202 WASHER
Kenmore 11043902203 WASHER
Kenmore 11044182400 COMPACT WASHER
Kenmore 11044182401 WASHER
Kenmore 11044722400 COMPACT WASHER
Kenmore 11044722401 RESIDENTIAL WASHER
Kenmore 11044826300 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044826301 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044832200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044832201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044832202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044834200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044834201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044834202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044836200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044836300 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044836301 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044921300 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044921301 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044921302 RESIDENTIAL WASHER
Kenmore 11044931300 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044931301 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044931302 RESIDENTIAL WASHER
Kenmore 11044932200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044932201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044932202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044932203 RESIDENTIAL WASHER
Kenmore 11044934200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044934201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044934202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044934203 RESIDENTIAL WASHER
Kenmore 11044936200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044936201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044936202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044936203 RESIDENTIAL WASHER
Kenmore 11045081400 RESIDENTIAL WASHER
Kenmore 11045081401 RESIDENTIAL WASHER
Kenmore 11045081402 RESIDENTIAL WASHER
Kenmore 11045081403 RESIDENTIAL WASHER
  #2 (permalink)
Old 01-05-2010, 05:26 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Since it seems to otherwise work I think your machine will need a new timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washing Machine Stops When Washing farmallnancy Washer Repair 1 12-01-2009 05:12 PM
Ice Machine Problems KimCarleton Refrigerator & Freezer Repair 0 10-06-2009 09:17 AM
GE Washing Problems thetaz Dishwasher Repair 5 05-01-2009 05:10 AM
washing machine jadesue Washer Repair 0 11-10-2007 01:46 PM
washing machine takes hours to finish washing a load kelly Monday Washer Repair 2 09-26-2007 02:42 AM
