Discuss
Top loader washer does not drain - pump problem?
 in
Washer Repair
I have a Whirlpool top loader washer that is around 10 years old and has run with no problems until
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Top loader washer does not drain - pump problem?
  #1 (permalink)
Old 01-02-2010, 07:15 PM
Junior Member
acurrier is on a distinguished road
Default Top loader washer does not drain - pump problem?
Model Number: WVSR1060A0WW   Brand: Whirlpool   Age: 5 - 10 years
I have a Whirlpool top loader washer that is around 10 years old and has run with no problems until this afternoon. The washer ran through its cycle but when I opened the top, the clothes were inside, under soapy water. I turned the dial back to rinse/spin and the basin did spin but the water did not drain. I took the hose out of the drain pipe in the wall, and when I put the end into a bucket, and turned the dial to spin, water came out slowly. When I took the hose out and laid it on the ground, water flowed pretty quickly (due to gravity). I siphoned and drained all the water out and unhooked the drain pipe. There was no blockage inside the hose or inside the washer. So I'm guessing it's the pump? Any ideas? Thanks in advance.
Ads By Google
Related Models
General Electric WVSR1060A0WW Washer
General Electric WVSR1060A1AA Washer
General Electric WVSR1060A1WW Washer
General Electric WVSR1060A2AA Washer
General Electric WVSR1060A2WW Washer
General Electric WVSR1060B0WW Washer
General Electric WVSR1060B3WW Washer
General Electric WVSR1060B4WW Washer
General Electric WVSR1060D0WW Washer
General Electric WVSR1060D2WW Washer
General Electric WVSR1060D5WW Washer
General Electric WVSR1060DAWW Washer
General Electric WVSR1060DBWW Washer
General Electric WVSR1060DCWW Washer
General Electric WVSR1060DDWW Washer
General Electric WVSR1060G0WW Washer
General Electric WVSR1060G2WW Washer
General Electric WVXR1040T2WW Washer
General Electric WVXR1040T3WW Washer
General Electric WVXR1040T4WW Washer
General Electric WVXR1040T5WW Washer
General Electric WVXR1040T8WW Washer
General Electric WVXR1040TAWW Washer
Jenn-Air WW2460B Walloven - S/c Ele
Jenn-Air WW2460W Walloven - S/c Ele
Jenn-Air WW27110B Walloven - S/c Ele
Jenn-Air WW27110W Walloven - S/c Ele
Jenn-Air WW27210B Walloven - S/c Ele
Jenn-Air WW27210P Walloven - S/c Ele
Jenn-Air WW27210PF Walloven - S/c Ele
Jenn-Air WW27210PG Walloven - S/c Ele
Jenn-Air WW27210PK Walloven - S/c Ele
Jenn-Air WW27210PR Walloven - S/c Ele
Jenn-Air WW27210PU Walloven - S/c Ele
Jenn-Air WW27210W Walloven - S/c Ele
Jenn-Air WW27430B Walloven - S/c Ele
Jenn-Air WW27430BC Walloven - S/c Ele
Jenn-Air WW27430P Walloven - S/c Ele
Jenn-Air WW27430PF Walloven - S/c Ele
Jenn-Air WW27430PG Walloven - S/c Ele
Jenn-Air WW27430PK Walloven - S/c Ele
Jenn-Air WW27430PR Walloven - S/c Ele
Jenn-Air WW27430PU Walloven - S/c Ele
Jenn-Air WW27430W Walloven - S/c Ele
Jenn-Air WW27430WC Walloven - S/c Ele
Jenn-Air WW2750B Walloven - S/c Ele
Jenn-Air WW2750W Walloven - S/c Ele
Jenn-Air WW2780B Walloven - S/c Ele
Jenn-Air WW2780B-C Walloven - S/c Ele
Jenn-Air WW2780W Walloven - S/c Ele
Jenn-Air WW2780W-C Walloven - S/c Ele
Whirlpool WW29000SU0 Laundry Worksurface
Whirlpool WW29000SW0 Laundry Worksurface
Jenn-Air WW30110B Walloven - S/c Ele
Jenn-Air WW30110W Walloven - S/c Ele
Jenn-Air WW30430B Walloven - S/c Ele
Jenn-Air WW30430P Walloven - S/c Ele
Jenn-Air WW30430PC Walloven - S/c Ele
Jenn-Air WW30430PF Walloven - S/c Ele
Jenn-Air WW30430PG Walloven - S/c Ele
Jenn-Air WW30430PK Walloven - S/c Ele
Jenn-Air WW30430PR Walloven - S/c Ele
Jenn-Air WW30430PU Walloven - S/c Ele
Jenn-Air WW30430W Walloven - S/c Ele
Frigidaire WW334AGW0 Wwh(v1) / Washer
Frigidaire WW334AGW1 Wwh(v2) / Washer
Frigidaire WW334AGW2 Wwh(v3) / Washer
Maytag WW600 Mwave - Cntrtp / Stand Alone
General Electric WWA3100BAL Washer
General Electric WWA3100GAL Washer
General Electric WWA3100GBL Washer
General Electric WWA3100VCL Washer
General Electric WWA3650MAL Washer
General Electric WWA3650RBL Washer
General Electric WWA3650SALAD Washer
General Electric WWA3650SALHA Washer
General Electric WWA3650SALWH Washer
General Electric WWA3657SALHA Washer
General Electric WWA3657SALWH Washer
General Electric WWA5009VCL Washer
General Electric WWA5304VNL Washer
General Electric WWA5304VPL Washer
General Electric WWA5400SALWH Washer
General Electric WWA5400SBLWH Washer
General Electric WWA5407MAL Washer
General Electric WWA5411BAL Washer
General Electric WWA5411GAL Washer
General Electric WWA5411VEL Washer
General Electric WWA5412BAL Washer
General Electric WWA5412GAL Washer
General Electric WWA5412VEL Washer
General Electric WWA5509VCL Washer
General Electric WWA5600BAL Washer
General Electric WWA5600GAL Washer
General Electric WWA5600GBL Washer
General Electric WWA5600RBL Washer
General Electric WWA5600SALAA Washer
General Electric WWA5600SALHA Washer
General Electric WWA5600SALWW Washer
General Electric WWA5600SBLAA Washer
General Electric WWA5600SBLWW Washer
General Electric WWA5600VCL Washer
General Electric WWA5610BAL Washer
General Electric WWA5636MAL Washer
General Electric WWA5669MAL Washer
General Electric WWA5669MBL Washer
General Electric WWA5710MAL Washer
General Electric WWA5710RBL Washer
General Electric WWA5710SALAA Washer
General Electric WWA5710SALWW Washer
General Electric WWA5710SBLAA Washer
General Electric WWA5710SBLWW Washer
General Electric WWA5800BAL Washer
General Electric WWA5800GAL Washer
General Electric WWA5800GBL Washer
General Electric WWA5800MAL Washer
General Electric WWA5800RBL Washer
General Electric WWA5800VCL Washer
General Electric WWA5809RBL Washer
General Electric WWA5826MAL Washer
  #2 (permalink)
Old 01-04-2010, 12:34 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
This is coming up as a GE not a Whirlpool, right?
That would make more sense, since the GE pump is electric and not connected to the motor as with the Whirlpool.
Confirm that the pump is getting power, which is probably the case since a little water is pumped out, and if so, then replacing the pump should do it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LG Washer Pump Drain Electrical Connections Matt Man 2 Dishwasher Repair 3 11-01-2009 01:30 AM
New pump but washer will still not drain FredPam Washer Repair 5 08-29-2009 04:01 PM
Washer Drain Pump Hose vikingollie Washer Repair 1 03-29-2009 02:29 PM
Spin and pump cycles stop and start, washer won't drain grosshaus Washer Repair 1 03-31-2008 02:10 PM
Noisy washer drain pump? mehullica Washer Repair 1 10-28-2007 01:04 PM
