I am wanting to replace my tub seal in my GE topload washer. Do I need to remove the whole tub from the machine to replace the tub seal or can it be done from the top after removing the agitator, agitator nut etc?? It is leaking from the bottom where the transmission goes into the bottom of the tub.
