Discuss
washer will not fill with water
 in
Washer Repair
washer had a lid switch malfunction (after my troubleshooting) earlier this morning. looked up the part & are ordering it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer will not fill with water
  #1 (permalink)
Old 01-01-2010, 04:10 PM
Junior Member
molarkey is on a distinguished road
Red face washer will not fill with water
Model Number: LSR5232LQ1   Brand: Whirlpool   Age: More than 10 years
washer had a lid switch malfunction (after my troubleshooting) earlier this morning. looked up the part & are ordering it ASAP. before i had a chance to bypass the switch (by splicing the 2 gray wires), my roommate went to use the washer without my knowledge.
the two gray wires were (i believe) touching the top cabinet housing & during the end of the fill cycle (right before it went to agitate), there was a spark & the it would not advance on the timer, even after i spliced the wire & tried to restart the fill cycle.
washer still gets power & all of the other cycles work: spin & drain. i also activated the timer during the rinse cycle to see if it would fill with water, but it only spins & it doesn't seem to advance at the end of it.
Ads By Google
Related Models
Whirlpool LSR5232LQ1 Automatic Washer
Whirlpool LSR5233AG0
Whirlpool LSR5233AN0
Whirlpool LSR5233AW0
Whirlpool LSR5233EQ0
Whirlpool LSR5233EQ1
Whirlpool LSR5233EQ2
Whirlpool LSR6132BN0
Whirlpool LSR6132BW0
Whirlpool LSR6132BW1
Whirlpool LSR6132DQ0
Whirlpool LSR6132DZ0
Whirlpool LSR6132EQ0
Whirlpool LSR6132EQ1
Whirlpool LSR6132EZ0
Whirlpool LSR6132EZ1
Whirlpool LSR6132HQ0
Whirlpool LSR6132HQ1
Whirlpool LSR6132HZ0
Whirlpool LSR6232JQ0
Whirlpool LSR6232JQ1
Whirlpool LSR6232JQ2 Automatic Washer
Whirlpool LSR6233BG0
Whirlpool LSR6233BN0
Whirlpool LSR6233BN1
Whirlpool LSR6233BW0
Whirlpool LSR6233BW1
Whirlpool LSR6233DN0
Whirlpool LSR6233DW0
Whirlpool LSR6244AG0
Whirlpool LSR6244AN0
Whirlpool LSR6244AW0
Whirlpool LSR6332KQ0
Whirlpool LSR6332KQ1 Automatic Washer
Whirlpool LSR6334LQ0
Whirlpool LSR6334LQ1 Automatic Washer
Whirlpool LSR6335LQ0
Whirlpool LSR7010PQ0 Automatic Washer
Whirlpool LSR7010PQ1 Automatic Washer
Whirlpool LSR7010PQ2 Automatic Washer
Whirlpool LSR7133KQ0
Whirlpool LSR7133KQ1 Automatic Washer
Whirlpool LSR7133PQ0 Automatic Washer
Whirlpool LSR7133PQ1 Automatic Washer
Whirlpool LSR7133PQ2 Automatic Washer
Whirlpool LSR7200EQ0
Whirlpool LSR7200EZ0
Whirlpool LSR7233BG0
Whirlpool LSR7233BG1
Whirlpool LSR7233BG2
Whirlpool LSR7233BN0
Whirlpool LSR7233BN1
Whirlpool LSR7233BN2
Whirlpool LSR7233BQ0
Whirlpool LSR7233BQ1
Whirlpool LSR7233BQ2
Whirlpool LSR7233BW0
Whirlpool LSR7233BW1
Whirlpool LSR7233BW2
Whirlpool LSR7233BZ0
Whirlpool LSR7233BZ2
Whirlpool LSR7233DQ0
Whirlpool LSR7233DQ1
Whirlpool LSR7233DW0
Whirlpool LSR7233DZ0
Whirlpool LSR7233DZ1
Whirlpool LSR7233EQ0
Whirlpool LSR7233EQ1
Whirlpool LSR7233EW0
Whirlpool LSR7233EZ0
Whirlpool LSR7233EZ1
Whirlpool LSR7233HQ0
Whirlpool LSR7233HZ0
Whirlpool LSR7300PQ0 Automatic Washer
Whirlpool LSR7300PQ1 Automatic Washer
Whirlpool LSR7300PQ2 Automatic Washer
Whirlpool LSR7333PQ0 Automatic Washer
Whirlpool LSR7333PQ1 Automatic Washer
Whirlpool LSR7333PQ3 Automatic Washer
Whirlpool LSR7333PQ4 Automatic Washer
Whirlpool LSR8010PQ0 Automatic Washer
Whirlpool LSR8010PQ1 Automatic Washer
Whirlpool LSR8010PQ2 Automatic Washer
Whirlpool LSR8010PT0 Automatic Washer
Whirlpool LSR8010PT1 Automatic Washer
Whirlpool LSR8010PT2 Automatic Washer
Whirlpool LSR8133HQ0
Whirlpool LSR8133HZ0
Whirlpool LSR8200EQ0
Whirlpool LSR8200EZ0
Whirlpool LSR8233EQ0
Whirlpool LSR8233EQ1
Whirlpool LSR8233EZ0
Whirlpool LSR8233EZ1
Whirlpool LSR8233JQ0
Whirlpool LSR8233JQ1
Whirlpool LSR8233JT0
Whirlpool LSR8233JT1
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0
Whirlpool LSR8433KQ1 Automatic Washer
Whirlpool LSR8433KQ2 Automatic Washer
Whirlpool LSR8433KT0
Whirlpool LSR8433KT1 Automatic Washer
Whirlpool LSR8433KT2 Automatic Washer
  #2 (permalink)
Old 01-01-2010, 04:46 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
The lid switch does not affect the fill cycle. That's controlled by the timer, the water level (pressure) switch, and the water inlet valve. If it isn't filling, first check to make sure the water source is supplying water. Then check to see if there is any obstruction or restriction to and from the valve. A common problem is sediment build-up in the inlet to the valve, especially the hot side. If everything is clear, try the fill in all the wash cycles. If you get water in one or more, but not in all cycles, replace the timer. The pressure switch rarely fails, but the air hose between the switch and the tub can become clogged or restricted. Take the end of the hose off the switch and blow into it to see if it is clear.
  #3 (permalink)
Old 01-02-2010, 09:52 AM
Junior Member
Default
the water source is supplying water. there is no obstruction or restriction either. washer was working fine until "spark" occurred. tried the fill in all cycles on the washer, no dice. doesn't even agitate, but all other functions in other cycles are operable as stated before.
the pressure switch could possibly be bad. the air hose between it & the tub were clear of any obstruction. blew into hose just to be sure.
i guess i'll order a new timer, but if that's not the case, it may be the pressure switch. i'm leaning towards a bad timer because it was in the process of changing from fill to agitate when "spark" occurred (& those are the only 2 parts of all cycles that don't work whatsoever).
  #4 (permalink)
Old 01-02-2010, 10:05 AM
Senior Expert
APP Volunteer
Default
One last check: Does it fill when you select "Rinse"? I also lean toward the timer as the culprit.
  #5 (permalink)
Old 01-02-2010, 10:10 AM
Junior Member
Default
nope. tried that already. sounds like the timer then.
  #6 (permalink)
Old 01-03-2010, 04:50 PM
Senior Expert
APP Volunteer
Default
It's probably the timer, then.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't fill with water peco Washer Repair 1 05-28-2009 06:27 PM
washer water won't fill andhow Washer Repair 0 07-18-2008 12:20 PM
Washer won't fill with water gimpy54 Washer Repair 6 07-03-2008 11:20 AM
washer doesn't fill with water cla Washer Repair 2 02-06-2008 03:30 PM
GE washer will not fill with water tex Dishwasher Repair 1 08-30-2007 11:33 AM
