:eek: machine is a nightmare! Initially Washer would not spin(would run for 5 minutes and shut off) r11 was burned on machine cntrl board. Replaced mach cntrl board and wax motor, machine still not spinning.Replaced timer, machine still not spinning:rolleyes: . Mach cntrl board now has a burned r52. something must be burning the board out. What should be replaced along with the machine cntrl board that is burning this board out:confused: .
Nightmare is the operative word for any Neptune based machine. You have our sympathies. Take a look at this tech bulletin on the board. Unfortunately you have already done what they suggest, so even though they do not mention it replacing the timer may be the solution. http://www.servicematters.com/m...ary/docs/TDL-0052A-B.pdf
