Discuss
Kenmore Agitates and Spins at the same time
 in
Washer Repair
Hello All, I have a Kenmore washer 90 series. The washer recently started agitating while in the spin mode. I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Agitates and Spins at the same time
  #1 (permalink)
Old 01-01-2010, 12:09 PM
Junior Member
Sorenson.Richard is on a distinguished road
Question Kenmore Agitates and Spins at the same time
Model Number: 11024904200   Brand: Kenmore   Age: More than 10 years
Hello All,
I have a Kenmore washer 90 series. The washer recently started agitating while in the spin mode. I know this not normal and do not know what may be causing the problem.
Thank you for your help.
Rich
Related Models
Kenmore 11024904200 AUTOMATIC WASHER
Kenmore 11024904201 AUTOMATIC WASHER
Kenmore 11024904202 AUTOMATIC WASHER
Kenmore 11024922200 AUTOMATIC WASHER
Kenmore 11024922201 AUTOMATIC WASHER
Kenmore 11024922202 AUTOMATIC WASHER
Kenmore 11024924200 AUTOMATIC WASHER
Kenmore 11024924201 AUTOMATIC WASHER
Kenmore 11024924202 AUTOMATIC WASHER
Kenmore 11024932200 AUTOMATIC WASHER
Kenmore 11024932201 AUTOMATIC WASHER
Kenmore 11024932202 AUTOMATIC WASHER
Kenmore 11024934200 AUTOMATIC WASHER
Kenmore 11024934201 AUTOMATIC WASHER
Kenmore 11024934202 AUTOMATIC WASHER
Kenmore 11024942300 AUTOMATIC WASHER
Kenmore 11024942301 RESIDENTIAL WASHER
Kenmore 11024944300 AUTOMATIC WASHER
Kenmore 11024944301 RESIDENTIAL WASHER
Kenmore 11024946300 AUTOMATIC WASHER
Kenmore 11024946301 RESIDENTIAL WASHER
Kenmore 11024952300 AUTOMATIC WASHER
Kenmore 11024952301 RESIDENTIAL WASHER
Kenmore 11024954300 AUTOMATIC WASHER
Kenmore 11024954301 RESIDENTIAL WASHER
Kenmore 11024956300 AUTOMATIC WASHER
Kenmore 11024956301 RESIDENTIAL WASHER
Kenmore 11024962300 AUTOMATIC WASHER
Kenmore 11024962301 RESIDENTIAL WASHER
Kenmore 11024964300 AUTOMATIC WASHER
Kenmore 11024964301 RESIDENTIAL WASHER
Kenmore 11024966300 AUTOMATIC WASHER
Kenmore 11024966301 RESIDENTIAL WASHER
Kenmore 11024972300 AUTOMATIC WASHER
Kenmore 11024974300 AUTOMATIC WASHER
Kenmore 11024982300 AUTOMATIC WASHER
Kenmore 11024992300 AUTOMATIC WASHER
Kenmore 11024994300 AUTOMATIC WASHER
Kenmore 11024996300 AUTOMATIC WASHER
Kenmore 11025062500 WASHER
Kenmore 11025064500 WASHER
Kenmore 11025066500 WASHER
Kenmore 11025292500 WASHER
Kenmore 11025292501 WASHER
Kenmore 11025292502 RESIDENTIAL WASHER
Kenmore 11025292503 RESIDENTIAL WASHER
Kenmore 11025294500 WASHER
Kenmore 11025294501 WASHER
Kenmore 11025294502 RESIDENTIAL WASHER
Kenmore 11025294503 RESIDENTIAL WASHER
Kenmore 11025832400 RESIDENTIAL WASHER
Kenmore 11025842400 AUTOMATIC WASHER
Kenmore 11025844400 AUTOMATIC WASHER
Kenmore 11025852400 AUTOMATIC WASHER
Kenmore 11025854400 AUTOMATIC WASHER
Kenmore 11025862400 AUTOMATIC WASHER
Kenmore 11025864400 AUTOMATIC WASHER
Kenmore 11026002010 AUTOMATIC WASHER
Kenmore 11026002011 AUTOMATIC WASHER
Kenmore 11026012010 AUTOMATIC WASHER
Kenmore 11026012011 AUTOMATIC WASHER
Kenmore 11026051690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026058690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026071690 COMMERCIAL WASHER
Kenmore 11026071691 COMMERCIAL WASHER
Kenmore 11026152500 WASHER COMMERCIAL
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
Kenmore 11026292693 AUTOMATIC WASHER
Kenmore 11026292694 WASHER
Kenmore 11026292695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026294690 AUTOMATIC WASHER
Kenmore 11026294691 AUTOMATIC WASHER
Kenmore 11026294692 AUTOMATIC WASHER
Kenmore 11026294693 AUTOMATIC WASHER
Kenmore 11026294694 WASHER
Kenmore 11026294695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026322500 WASHER
Kenmore 11026322501 WASHER
Kenmore 11026322502 RESIDENTIAL WASHER
Kenmore 11026322503 RESIDENTIAL WASHER
Kenmore 11026332500 RESIDENTIAL WASHER
Kenmore 11026332501 WASHER
Kenmore 11026332502 RESIDENTIAL WASHER
Kenmore 11026332503 RESIDENTIAL WASHER
Kenmore 11026342500 RESIDENTIAL WASHER
Kenmore 11026342501 WASHER
Kenmore 11026342502 RESIDENTIAL WASHER
Kenmore 11026342503 RESIDENTIAL WASHER
Kenmore 11026422500 RESIDENTIAL WASHER
Kenmore 11026422501 WASHER
Kenmore 11026422502 RESIDENTIAL WASHER
Kenmore 11026422503 RESIDENTIAL WASHER
Kenmore 11026432500 WASHER
Kenmore 11026432501 WASHER
Kenmore 11026432502 RESIDENTIAL WASHER
Kenmore 11026432503 RESIDENTIAL WASHER
Kenmore 1102644182 RESIDENTIAL WASHER
Kenmore 11026442500 WASHER
Kenmore 11026442501 WASHER
Kenmore 11026442502 RESIDENTIAL WASHER
Kenmore 11026442503 RESIDENTIAL WASHER
Kenmore 1102644722 RESIDENTIAL WASHER
Kenmore 11026622690 WASHER
Kenmore 11026622691 AUTOMATIC WASHER
Kenmore 11026632500 WASHER
Kenmore 11026632501 WASHER
Kenmore 11026632502 WASHER
Kenmore 11026632503 RESIDENTIAL WASHER
Kenmore 11026642500 WASHER
Kenmore 11026642501 washer
Kenmore 11026642502 WASHER
Kenmore 11026642503 RESIDENTIAL WASHER
Kenmore 11026652500 WASHER
Kenmore 11026652501 WASHER
Kenmore 11026652502 WASHER
Kenmore 11026652503 RESIDENTIAL WASHER
Kenmore 11026682503 RESIDENTIAL WASHER
Kenmore 11026692503 RESIDENTIAL WASHER
  #2 (permalink)
Old 01-03-2010, 08:14 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
This is the classic symptom of a failed transmission. If you decide to replace it then you should also replace the clutch and motor coupling while you have it open, so you need to decide if you want to put about $200.00+ in parts into it or get a new one.
The labor is fairly easy to do so you can do it yourself, but given the cost and the age of your machine you may want to spend a little more and get a new, no frills top loader.
Let us know if you decide to repair it and need some help.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore washer fills and agitates at same time. Tommy61 Washer Repair 3 01-09-2011 04:54 AM
Washer barely spins or agitates. MommaJesi Washer Repair 1 12-31-2009 04:39 PM
80 Series, Agitates but only spins if prompted. goneboarding007 Washer Repair 4 12-30-2009 01:56 PM
No Water - Washer Spins & Agitates jsolo53 Washer Repair 7 09-23-2009 06:16 PM
washer agitates and spins - won't fill wdhammy Washer Repair 3 03-27-2009 01:06 PM
