Discuss
washer overfills
 in
Washer Repair
My washer overfills at the beginning of a cycle. Then sometimes it does not fill at all on the rinse
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer overfills
  #1 (permalink)
Old 01-01-2010, 06:36 AM
Junior Member
roosterest is on a distinguished road
Default washer overfills
Model Number: LLR9245DQ0   Brand: Whirlpool   Age: 5 - 10 years
My washer overfills at the beginning of a cycle. Then sometimes it does not fill at all on the rinse cycle, only agitating. Actually the agitation seems sluggish as well.
Ads By Google
Related Models
Whirlpool LLR9245DQ0
Whirlpool LLR9245DQO WHIRLPOOL WASHER
Whirlpool LLR9245DZ0
Whirlpool LLR9245DZO WHIRLPOOL WASHER
Whirlpool LLT7144AN0 Washers*
Whirlpool LLT7144BN0
Whirlpool LLT7144BQ0
Whirlpool LLT7144BQ1
Whirlpool LLT7144BW0
Whirlpool LLT7144DQ0
Whirlpool LLT8233AN0
Whirlpool LLT8233AQ0
Whirlpool LLT8233AW0
Whirlpool LLT8233AW1 AUTOMATIC WASHER
Whirlpool LLT8233AW2
Whirlpool LLT8233DQ0
Whirlpool LLT8233DZ0
Whirlpool LLT8244AN0
Whirlpool LLT8244AQ0
Whirlpool LLT8244AW0
Whirlpool LLT8244AZ0
Whirlpool LLT8244BQ0
Whirlpool LLT8244BQ1
Whirlpool LLT8244BZ0
Whirlpool LLT8244BZ1
Whirlpool LLT8244DQ0
Whirlpool LLT8244DZ0
Whirlpool LLV6144AG0
Whirlpool LLV6144AN0
Whirlpool LLV6144AW0
Whirlpool LLV6144BN0
Whirlpool LLV6144BW0
Whirlpool LLV7233AW0
Whirlpool LLV7244AG0
Whirlpool LLV7244AN0
Whirlpool LLV7244AW0
Whirlpool LLV8233BN0
Whirlpool LLV8233BQ0
Whirlpool LLV8233BW0
Whirlpool LLV8245AG0
Whirlpool LLV8245AN0
Whirlpool LLV8245AW0
Whirlpool LLV8245BN0
Whirlpool LLV8245BW0
Whirlpool LLV8245DQ0
Whirlpool LLV8245DZ0
 LM-1830C2L Air Conditioner
 LM-2430C2L Air Conditioner
 LM-2430H2L Air Conditioner
 LM360CE Air Conditioner
Whirlpool LMA1053LQ0
Whirlpool LMA1053LT0
 LMA1150SV Microwave Oven
 LMA1560SB Microwave Oven
 LMA2111ST Microwave Oven
 LMAN090CNS.ANCAEUS Air Conditioner
 LMAN090HNS Air Conditioner
 LMAN120CNS Air Conditioner
 LMAN120HNS Air Conditioner
 LMAN121CNM Air Conditioner
 LMAN121HNM Air Conditioner
 LMH1017CVST Microwave Oven
 LMN090CE.AWHAEUS Air Conditioner
 LMN090HE Air Conditioner
 LMN120EC.AWHAEUS Air Conditioner
 LMN120HE Air Conditioner
 LMN2430H2L Air Conditioner
Whirlpool LMR4131AN0
Whirlpool LMR4131AW0
Whirlpool LMR4132BW0
Whirlpool LMR4232AN0
Whirlpool LMR4232AW0
Whirlpool LMR5243AN0
Whirlpool LMR5243AN1
Whirlpool LMR5243AW0
Whirlpool LMR5243AW1
 LMU180HE Air Conditioner
 LMU1830C2L Air Conditioner
 LMU240CE.AWGAEUS Air Conditioner
 LMU240HE Air Conditioner
 LMU2430C2L Air Conditioner
 LMU360CE Air Conditioner
 LMU360HE Air Conditioner
 LMV-1975ST Microwave Oven
 LMV1314B Microwave Oven
 LMV1314SV Microwave Oven
 LMV1314W Microwave Oven
 LMV1625B Microwave Oven
 LMV1625W Microwave Oven
 LMV1630BB Microwave Oven
 LMV1630ST Microwave Oven
 LMV1630WW Microwave Oven
 LMV1635SB Microwave Oven
 LMV1635SBQ Microwave Oven
 LMV1635SW Microwave Oven
 LMV1680ST Microwave Oven
 LMV1680WW Microwave Oven
 LMV1825SB Microwave Oven
 LMV1825SBQ Microwave Oven
 LMV1915NVB Microwave Oven
 LMV1925SB Microwave Oven
 LMV1925SBQ Microwave Oven
 LMV1925SW Microwave Oven
 LMV1976ST Microwave Oven
 LMV2053SB Microwave Oven
 LMV2053ST Microwave Oven
 LMV2053SW Microwave Oven
 LMV2061SB Microwave Oven
 LMV2073BB Microwave Oven
 LMV2073ST Microwave Oven
 LMV2073WW Microwave Oven
 LMV2083SB Microwave Oven
 LMV2083ST Microwave Oven
 LMV2083SW Microwave Oven
Whirlpool LMV5243AN0
Whirlpool LMV5243AW0
 LMVH1750ST Microwave Oven
  #2 (permalink)
Old 01-02-2010, 06:42 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
The problem may be in your valve assembly or the water pressure system. Use a meter to check that 120v is getting to the valves when the machine is supposed to be filling and that the 120v stops when you stop the machine. If the valves assembly is getting current but does not open, or if it does not stop filling when the machine is turned off, the problem is probably in the valve assembly.
The water filling is controlled by a pressure driven switch. From the switch to the tub is a plastic tube. As water enters the tub, air pressure inside the tube increases and when it gets to a pre-designated level it tells the pressure switch to shut off the water. The pressure switch then tells the timer to shut off the water and the water shuts off.
Take off the cabinet, this site will show you how.
Kenmore top loader blues (SublimeMasterJW's Appliance Advice)
and clean out the plastic tube. If that does not fix things, put the machine on start and when it starts to fill with water blow into the tube and see if that makes it stop. If so, the pressure switch is bad. Unfortunately yours is one of the more expensive varieties.
Part number: AP3018879
__________________
  #3 (permalink)
Old 01-03-2010, 11:12 AM
Junior Member
Default Thank you!!!
Your info has been VERY helpful. I am just getting to the meat of the problem (I first had to switch out both the hot & cold water valves). I am not sure how to check the volt stuff so I am going to try to eliminate the other stuff first. Any other info will be appreciated, but you have managed to take the "mystery" of the washing machine away & that is HUGE. I removed the cabinet very easily.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer overfills jeff 72 Washer Repair 1 08-21-2009 04:29 AM
washer overfills when on dave titan Washer Repair 1 04-28-2009 08:07 PM
washer overfills BSA_T524 Washer Repair 1 08-10-2008 12:13 AM
Washer overfills and won't agitate Rayenglert1 Washer Repair 0 06-03-2008 01:08 PM
Washer overfills LSUKixAss1 Washer Repair 3 01-23-2008 06:36 PM
