Discuss
Wash machine starts on different segment of wash cycle than what we set it to
 in
Washer Repair
We set our washing machine to the normal starting position and instead of filling with water it jumps right to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Wash machine starts on different segment of wash cycle than what we set it to
  #1 (permalink)
Old 12-30-2009, 05:28 PM
Junior Member
rbarnes18 is on a distinguished road
Default Wash machine starts on different segment of wash cycle than what we set it to
Model Number: LSQ8243HQ0   Brand: Whirlpool   Age: 5 - 10 years
We set our washing machine to the normal starting position and instead of filling with water it jumps right to the agitation cycle. We have tried all the different types of cycles (delicate, normal, etc) and we get similar results. The wash machine does not start where the dial is pointed. Any advice???
Ads By Google
Related Models
Whirlpool LSQ8243HQ0
Whirlpool LSQ8243HZ0
Whirlpool LSQ8500JQ0
Whirlpool LSQ8500JQ1
Whirlpool LSQ8500JQ2
Whirlpool LSQ8500JT0
Whirlpool LSQ8500JT1
Whirlpool LSQ8500JT2
Whirlpool LSQ8500LQ0 Automatic Washer
Whirlpool LSQ8510LQ0 Automatic Washer
Whirlpool LSQ8511KQ0
Whirlpool LSQ8511KT0
Whirlpool LSQ8512KQ0
Whirlpool LSQ8512KT0
Whirlpool LSQ8520JQ0
Whirlpool LSQ8520JQ1
Whirlpool LSQ8543JQ0
Whirlpool LSQ8543JQ1
Whirlpool LSQ8543JT0
Whirlpool LSQ8543JT1
Whirlpool LSQ8543JZ0
Whirlpool LSQ8543JZ1
Whirlpool LSQ9010KQ0
Whirlpool LSQ9010KT0
Whirlpool LSQ9010LG0
Whirlpool LSQ9010LG1 Automatic Washer
Whirlpool LSQ9010LG2 Automatic Washer
Whirlpool LSQ9010LG3 Automatic Washer
Whirlpool LSQ9010LQ0
Whirlpool LSQ9010LQ1 Automatic Washer
Whirlpool LSQ9010LQ2 Automatic Washer
Whirlpool LSQ9010LW0
Whirlpool LSQ9010LW1 Automatic Washer
Whirlpool LSQ9010LW2 Automatic Washer
Whirlpool LSQ9010LW3 Automatic Washer
Whirlpool LSQ9010PG0 Automatic Washer
Whirlpool LSQ9010PG1 Automatic Washer
Whirlpool LSQ9010PG2 Automatic Washer
Whirlpool LSQ9010PG3 Automatic Washer
Whirlpool LSQ9010PG5 Automatic Washer
Whirlpool LSQ9010PG6 Automatic Washer
Whirlpool LSQ9010PW0 Automatic Washer
Whirlpool LSQ9010PW1 Automatic Washer
Whirlpool LSQ9010PW2 Automatic Washer
Whirlpool LSQ9010PW3 Automatic Washer
Whirlpool LSQ9010PW5 Automatic Washer
Whirlpool LSQ9010PW6 Automatic Washer
Whirlpool LSQ9030PQ0 Automatic Washer
Whirlpool LSQ9030PQ1 Automatic Washer
Whirlpool LSQ9030PQ2 Automatic Washer
Whirlpool LSQ9030PQ4 Automatic Washer
Whirlpool LSQ9030PQ5 Automatic Washer
Whirlpool LSQ9110KQ0
Whirlpool LSQ9110KQ1
Whirlpool LSQ9110LG0
Whirlpool LSQ9110LG1 Automatic Washer
Whirlpool LSQ9110LW0
Whirlpool LSQ9110LW1 Automatic Washer
Whirlpool LSQ9110PW0 Automatic Washer
Whirlpool LSQ9110PW1 Automatic Washer
Whirlpool LSQ9110PW2 Automatic Washer
Whirlpool LSQ9110PW3 Automatic Washer
Whirlpool LSQ9110PW4 Automatic Washer
Whirlpool LSQ9200KQ0
Whirlpool LSQ9200KT0
Whirlpool LSQ9200LQ0
Whirlpool LSQ9200LQ1 Automatic Washer
Whirlpool LSQ9200LQ2 Automatic Washer
Whirlpool LSQ9200LQ3 Automatic Washer
Whirlpool LSQ9200LT0
Whirlpool LSQ9200LT1 Automatic Washer
Whirlpool LSQ9200LT2 Automatic Washer
Whirlpool LSQ9200LT3 Automatic Washer
Whirlpool LSQ9200PQ0 Automatic Washer
Whirlpool LSQ9200PQ1 Automatic Washer
Whirlpool LSQ9200PQ3 Automatic Washer
Whirlpool LSQ9200PQ4 Automatic Washer
Whirlpool LSQ9200PT0 Automatic Washer
Whirlpool LSQ9200PT1 Automatic Washer
Whirlpool LSQ9200PT3 Automatic Washer
Whirlpool LSQ9200PT4 Automatic Washer
Whirlpool LSQ9210HQ0
Whirlpool LSQ9210HZ0
Whirlpool LSQ9211KQ0
Whirlpool LSQ9211KQ1
Whirlpool LSQ9211KT0
Whirlpool LSQ9211KT1
Whirlpool LSQ9244EQ0
Whirlpool LSQ9244EZ0
Whirlpool LSQ9264HQ0
Whirlpool LSQ9264HZ0
Whirlpool LSQ9500LQ0
Whirlpool LSQ9500LT0
Whirlpool LSQ9510JQ0
Whirlpool LSQ9510JQ1
Whirlpool LSQ9510LQ0
Whirlpool LSQ9510LT0
Whirlpool LSQ9520LQ0
Whirlpool LSQ9520LT0
Whirlpool LSQ9544KQ0
Whirlpool LSQ9544KT0
Whirlpool LSQ9549LG0
Whirlpool LSQ9549LG1 Automatic Washer
Whirlpool LSQ9549LG2 Automatic Washer
Whirlpool LSQ9549LG3 Automatic Washer
Whirlpool LSQ9549LQ0
Whirlpool LSQ9549LQ1 Automatic Washer
Whirlpool LSQ9549LQ2 Automatic Washer
Whirlpool LSQ9549LQ3 Automatic Washer
Whirlpool LSQ9549LW0
Whirlpool LSQ9549LW1 Automatic Washer
Whirlpool LSQ9549LW2 Automatic Washer
Whirlpool LSQ9549LW3 Automatic Washer
Whirlpool LSQ9549PG0 Automatic Washer
Whirlpool LSQ9549PG1 Automatic Washer
Whirlpool LSQ9549PG2 Automatic Washer
Whirlpool LSQ9549PG3 Automatic Washer
Whirlpool LSQ9549PG5 Automatic Washer
Whirlpool LSQ9549PG6 Automatic Washer
Whirlpool LSQ9549PW0 Automatic Washer
  #2 (permalink)
Old 01-01-2010, 07:03 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I think your water level switch is stuck in the closed position. It is telling the timer that the machine is filled to the correct level of water and to start agitating. (I assume the same thing happens on the rinse cycle).
You should try replacing the water level switch. If you want to try to test it out and are not to picky, (I am not, but then I do some pretty gross things working on these machines anyway) you can take it off and suck on the plastic extension that the tube connects to. You may be to unstick it in this way. If you can, I would still replace it, as this will tell you that you have a high probability of sucess in doing so.
Here is the new part.
Part number: AP3019752
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washing machine very loud in wash and spin cycle shoes4419 Washer Repair 7 07-22-2009 11:31 AM
When wash is complete the machine stay on agitate and won't allow a new wash cycle Trofytrout Washer Repair 1 07-07-2009 01:34 PM
Washer starts and stops during wash cycle ballardg Washer Repair 1 02-27-2009 04:28 PM
dull grinding noise after wash cycle starts kjd1159 Dishwasher Repair 0 07-23-2008 05:20 PM
Can not select wash cycle - stuck on scrub wash luke Dishwasher Repair 0 08-20-2007 08:38 AM
