Discuss
Ted
 in
Washer Repair
Hi, the agitator seems to be stripped. It spins freely in either dirction when not in use and does not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Ted
  #1 (permalink)
Old 03-24-2008, 12:02 PM
Ted Ted is offline
Junior Member
Ted is on a distinguished road
Default Ted
Model Number: 110-18522790   Brand: Kenmore   Age: 5 - 10 years
the agitator seems to be stripped. It spins freely in either dirction when not in use and does not agitate when machin is operational. You can hear it lightly grinding as the inside assembly rotates but the agitator does not.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-25-2008, 11:27 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Ted,
The agitator consists of two major parts: the bottom part called "agitator" and the top part called "auger".
If the auger moves freely in both directions then the problem is a bad agitator clutch dogs (#5 on the break down diagram).
If the agitator does it then the problem is a worn out splines inside the agitator or on the gear case shaft.
Most likely the problem with your washer caused by a bad agitator clutch dogs. In order to fix it you have to use the agitator repair kit.
- The part number for the agitator repair kit is AP3094520
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
