My washer works well, except when it comes to the spinning cycle. I tried replacing the coupler but it didn't work. Can you please advice me as to what the problem is.
I am assuming your machine will spin slow, or spin sometimes, or spin if you give it a little hand push to start it. In that case you want to check out the clutch and probably replace it. See the Sticky by Richappy above and this site on clutch replacement. Clutch Replacement on Whirlpool and Kenmore Washers
