| » Washer leaves water in tub, intermitantly starts when restarted |
Model Number: TAWSS800JQ0 Brand: Estate Age: 5 - 10 years
When running a cycle the unit leaves excess water in the tub. When attempting to restart the spin cycle or other cycles, they only start occasionally when the selector is relocated. When it does drain/pump down, it seems to run OK, until it stops. This started nearly one month ago and has gradually gotten worse to the point now that it is more than an inconvenience. Any ideas?
Thank you very much Ads By Google Related Models |
I am not getting your model to come up, but assuming this is a basic Whirlpool direct driver washer you need to take off the cabinet and check the pump and drain hoses for an obstruction.
This video will show you how. YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
__________________
| Display Modes | |
| washer leaves inch of water when done | mowsise | Washer Repair | 1 | 07-30-2009 04:18 PM |
| water starts filling, half way, it starts draining | al1544 | Washer Repair | 2 | 06-17-2009 11:06 PM |
| Washer intermitantly leaves cloths wet | james King | Washer Repair | 1 | 02-26-2008 04:31 AM |
| Washer intermitantly leaves cloths wet | james King | Washer Repair | 0 | 11-30-2007 12:29 PM |
| Washer leaves black marks when using cold water | triskit22 | Washer Repair | 1 | 09-19-2007 05:35 PM |
