Groups ready for retrieval: Registered
Today, I replaced the drive coupler on this machine after finding it broken when the spin cycle stopped working. Thought I had the machine fixed, but when I put everything back together and started a load, it flipped off the breaker switch within a few seconds of starting into the agitation cycle after it filled. The load was no bigger than any other load we have washed before. I had ran it empty in the spin cycle before putting a load in (after I replaced the coupler) and it flipped the switch in that mode after about 10-15 seconds, also. Is this a motor problem, or could the new coupler be too tight and putting too much strain on the motor? Thanks in advance for any help.
Carefully check the motor connector, you may have bent a pin in there when you put it back together.
