Discuss
Whirlpool won't fill w/ Water, skips to agitate/wash cycle.
 in
Washer Repair
My Whirlpool Washer stated intermitently skipping the fill cycle and moving directly to the agitate/wash cycle. I believe the rinse
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool won't fill w/ Water, skips to agitate/wash cycle.
  #1 (permalink)
Old 12-26-2009, 05:06 PM
Junior Member
jeshurun41 is on a distinguished road
Default Whirlpool won't fill w/ Water, skips to agitate/wash cycle.
Model Number: LSR8233EQ1   Brand: Whirlpool   Age: 5 - 10 years
My Whirlpool Washer stated intermitently skipping the fill cycle and moving directly to the agitate/wash cycle. I believe the rinse cycle is avoided as well. Started noticing the problem a couple of weeks ago, and it first seemed to be remedied by switching the water level knob from "small" to "medium," then the agitator would stop and the tub began to fill. Sometimes the problem would not be present at all and the machine would work properly. Now the problem has worsened to the point where at any wash setting the machine will not fill but jumps to the agitate/wash cycle.
The hoses are not kinked or clogged, neither are the screens. Since it will at times fill with water after messing w/ the H20 level knob, I believe the water inlet valve is working properly. Is it the H20 level switch that is bad, or is the timer not sending power to the H20 inlet valve to open to allow the machine to fill?
Related Models
Whirlpool LSR8233EQ1 AUTOMATIC WASHER
Whirlpool LSR8233EZ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EZ1 AUTOMATIC WASHER
Whirlpool LSR8233JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JQ1 WASHER
Whirlpool LSR8233JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JT1 WASHER
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0 WASHER
Whirlpool LSR8433KQ1 AUTOMATIC WASHER
Whirlpool LSR8433KQ2 AUTOMATIC WASHER
Whirlpool LSR8433KT0 WASHER
Whirlpool LSR8433KT1 AUTOMATIC WASHER
Whirlpool LSR8433KT2 AUTOMATIC WASHER
Whirlpool LSR8444LQ0 WASHER
Whirlpool LSR8444LQ1 AUTOMATIC WASHER
Whirlpool LSR8444LT0 WASHER
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 AUTOMATIC WASHER
Whirlpool LSR9434PQ1 AUTOMATIC WASHER
Whirlpool LSR9434PQ3 AUTOMATIC WASHER
Whirlpool LSR9434PQ4 AUTOMATIC WASHER
Whirlpool LSR9434PT0 AUTOMATIC WASHER
Whirlpool LSR9434PT1 AUTOMATIC WASHER
Whirlpool LSR9434PT3 AUTOMATIC WASHER
Whirlpool LSR9434PT4 AUTOMATIC WASHER
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
General Electric LSS25XSWASS REFRIGERATOR W SERIES
General Electric LSS25XSWCSS REFRIGERATOR W SERIES
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0 WASHER
Whirlpool LSS9244EZ0 WASHER
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
Whirlpool LST9245AN0
Whirlpool LST9245AW0
Whirlpool LST9245BN1
Whirlpool LST9245BQ0
Whirlpool LST9245BQ2
Whirlpool LST9245BW1
Whirlpool LST9245BZ0
Whirlpool LST9245BZ2
Whirlpool LST9355AN0
Whirlpool LST9355AW0
Whirlpool LST9355BN0
Whirlpool LST9355BQ0
Whirlpool LST9355BQ1
Whirlpool LST9355BW0
Whirlpool LST9355BZ0
Whirlpool LST9355BZ1
Whirlpool LST9355DQ0
Whirlpool LST9355DZ0
 LSU090HE Air Conditioner
 LSU092CE Air Conditioner
 LSU092HE Air Conditioner
 LSU120HE Air Conditioner
 LSU122CE Air Conditioner
 LSU122HE Air Conditioner
 LSU180HE Air Conditioner
 LSU182CE Air Conditioner
  #2 (permalink)
Old 12-26-2009, 06:31 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
The end of the air tube that runs from the water level pressure switch to the bottom of the wash tube maybe plugged.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 12-27-2009, 04:09 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
You might have a bad water level switch. I would remove the plastic hose from the bottom of the tub that goes to the water level switch. Blow gently in it. If the switch never makes a clicking noise, replace it.
If ok, I would re-attach it to the tub, remove it from the water level switch and blow in it to clear soap residue in it, then force some vinegar down it with a turkey baster, should fix it. Water level switch AP3019752
__________________
  #4 (permalink)
Old 12-27-2009, 04:29 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I think that the water level switch may be toast.
It sounds like the contacts in the switch are sticking in the actuated position so the unit thinks it is full of water when in reality it is empty.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
skips wash cycle troyvb Washer Repair 1 12-08-2009 03:49 PM
dishwasher skips wash cycle bobgascoigne Dishwasher Repair 0 11-15-2009 06:07 PM
Dishwasher skips the wash cycle and stops at the rinse cycle jasporo Dishwasher Repair 6 06-08-2009 04:11 PM
Kenmore Dishwasher skips wash cycle shebee10 Dishwasher Repair 0 10-10-2008 11:46 AM
normal wash cycle skips minutes BRB Dishwasher Repair 0 05-08-2008 08:13 AM
