Discuss
GE WHDSR209D5WW Starts filling then stops
 in
Washer Repair
Symptoms; Washer starts filling. Approximatly a quart or less of either cold, warm or hot water then stops filling. A
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE WHDSR209D5WW Starts filling then stops
  #1 (permalink)
Old 12-26-2009, 10:58 AM
Junior Member
daveclizbe is on a distinguished road
Default GE WHDSR209D5WW Starts filling then stops
Model Number: WHDSR209D5WW   Brand: GE   Age: 5 - 10 years
Symptoms;
Washer starts filling. Approximatly a quart or less of either cold, warm or hot water then stops filling. A loud humming from the water inlet relay(s) is heard. Cycle doesn't advance.
Tests ran;
Checked the water pressure switch and line, it works fine and the line is clear. Removed the pump and tested it. It works fine. Checked water inlet valves for sediment, they are clear. Water inlet hoses are new.
History;
Machine originally started stalling during the rinse cycle. Problem began after moving machine slightly over a mile to a new residence several months ago. Was able to manually move timer past stall point to complete cylce. Recently, past couple of wash loads using warm and hot cycles ran fine until rinse cycle. Cold, however, filled slightly then stalled. Now all cycles are stalling in the initial fill after releasing a quart or less of water. I suspect the water inlet valve has gone bad. Please advise.
Thank you,
Dave Clizbe
Related Models
General Electric WHDSR209D5WW Washer
General Electric WHDSR209D6WW Washer
General Electric WHDSR209D7WW Washer
General Electric WHDSR209DAWW Washer
General Electric WHDSR209DBWW Washer
General Electric WHDSR209DCWW Washer
General Electric WHDSR209DDWW Washer
General Electric WHDSR209G0WW Washer
General Electric WHDSR209G2WW Washer
General Electric WHDSR209G3WW WASHER
General Electric WHDSR209G8WW WASHER
General Electric WHDSR209G9WW WASHER
General Electric WHDSR315D0WW Washer
General Electric WHDSR315D5WW Washer
General Electric WHDSR315DAWW Washer
General Electric WHDSR315DBWW Washer
General Electric WHDSR315DCWW Washer
General Electric WHDSR315DDWW WASHER
General Electric WHDSR316G0WW Washer
General Electric WHDSR316G1WW WASHER
General Electric WHDSR316G2WW WASHER
General Electric WHDSR316G3WW WASHER
General Electric WHDSR316G4WW WASHER
General Electric WHDSR316G5WW WASHER
General Electric WHDSR316G6WW WASHER
General Electric WHDSR417D0WW Washer
General Electric WHDSR417D5WW Washer
General Electric WHDVH626F0GG Washer
General Electric WHDVH626F0WW Washer
General Electric WHDVH626H1GG WASHER
General Electric WHDVH626H1WW WASHER
General Electric WHDVH660H0BB Washer
General Electric WHDVH660H0GG Washer
General Electric WHDVH660H0MB WASHER
General Electric WHDVH660H0MS WASHER
General Electric WHDVH660H0WW Washer
General Electric WHDVH660H1BB WASHER
General Electric WHDVH660H1GG WASHER
General Electric WHDVH660H1MB WASHER
General Electric WHDVH660H1MS WASHER
General Electric WHDVH660H1WW WASHER
General Electric WHDVH680J0BB WASHER
General Electric WHDVH680J0GG WASHER
General Electric WHDVH680J0MB WASHER
General Electric WHDVH680J0MR WASHER
General Electric WHDVH680J0MS WASHER
General Electric WHDVH680J0WW WASHER
General Electric WHDVH680J1MR WASHER
General Electric WHDVH680J1MS WASHER
General Electric WHDVH680J1WW WASHER
Whirlpool WHE33311 30" Electric Range
Whirlpool WHE383311 30" ELECTRIC RANGE COOKTOP
Whirlpool WHP1000SB1 PEDESTAL
Whirlpool WHP1000SK0 PEDESTAL
Whirlpool WHP1000SK1 PEDESTAL
Whirlpool WHP1000SL0 PEDESTAL
Whirlpool WHP1000SL1 PEDESTAL
Whirlpool WHP1000SQ0 PEDESTAL
Whirlpool WHP1000SQ1 PEDESTAL
Whirlpool WHP1000ST0 PEDESTAL
Whirlpool WHP1000ST1 PEDESTAL
Whirlpool WHP1000SU1 PEDESTAL
Whirlpool WHP1500SA0 PEDESTAL
Maytag WHP1500SA1 PEDESTAL
Whirlpool WHP1500SB0 PEDESTAL
Maytag WHP1500SB1 PEDESTAL
Whirlpool WHP1500SC0 PEDESTAL
Maytag WHP1500SC1 PEDESTAL
Whirlpool WHP1500SL0 PEDESTAL
Maytag WHP1500SL1 PEDESTAL
Whirlpool WHP1500SQ0 PEDESTAL
Maytag WHP1500SQ1 PEDESTAL
Whirlpool WHP1500ST0 PEDESTAL
Maytag WHP1500ST1 PEDESTAL
Whirlpool WHP1500SU0 PEDESTAL
Maytag WHP1500SU1 PEDESTAL
Whirlpool WHP32812 30" Electric Range Self Clean Oven
Whirlpool WHP54802 30" Electric Range Self Clean Oven
Whirlpool WHP54803 30" Electric Range Self Clean Oven
Whirlpool WHP83812 30" ELECTRIC RANGE CERAN COOKTOP SELF CLEAN
General Electric WHRE5260E0CC Washer
General Electric WHRE5260E0WW Washer
General Electric WHRE5260E1CC Washer
General Electric WHRE5260E1WW Washer
General Electric WHRE5260E6CC Washer
General Electric WHRE5260E6WW Washer
General Electric WHRE5550H0WW WASHER
General Electric WHRE5550H1WW WASHER
General Electric WHRE5550H2WW WASHER
General Electric WHRE5550K0WW WASHER
General Electric WHRE5550K1WW WASHER
General Electric WHRE5550K2WW WASHER
General Electric WHRE5550K3WW WASHER
General Electric WHSB8000B0CC Washer
General Electric WHSB8000B0WW Washer
General Electric WHSB8000B1CC Washer
General Electric WHSB8000B1WW Washer
General Electric WHSB9000B0CC Washer
General Electric WHSB9000B0WC Washer
General Electric WHSB9000B0WW Washer
General Electric WHSE3100A0WB Washer
General Electric WHSE3100A2WB Washer
General Electric WHSE5240D0CC Washer
General Electric WHSE5240D0WW Washer
General Electric WHSE5240D1CC Washer
General Electric WHSE5240D1WW Washer
General Electric WHSE5240DCCC Washer
General Electric WHSE5240DCWW Washer
General Electric WHSR2070V2WB Washer
General Electric WHSR2070V3WB Washer
General Electric WICB103CV1WC Washer
Frigidaire WIDH3 Frg(v18) / Top Loading Washer
Frigidaire WIDH4 Frg(v3) / Top Load Washer
Frigidaire WIDL3 Frg(v19) / Top Loading Washer
Frigidaire WIDL4 Frg(v2) / Top Load Washer
Frigidaire WIDW3 Frg(v20) / Top Loading Washer
Frigidaire WIDW4 Frg(v1) / Top Load Washer
Frigidaire WILH1 Frg(v2) / 27 " Washer
Frigidaire WILL0 Frg(v2) / 27 " Washer
Frigidaire WILL1 Frg(v3) / 27 " Washer
  #2 (permalink)
Old 12-26-2009, 10:30 PM
Senior Member
applianceman is on a distinguished road
Default
I think you are right about the water inlet valve being bad. Just make sure you have good water pressure coming to the machine and if so replace the water valve. Clothes Washer Repair Guide
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
starts/stops by self andrew lacey Dishwasher Repair 0 07-10-2009 01:13 PM
water starts filling, half way, it starts draining al1544 Washer Repair 2 06-17-2009 11:06 PM
Washer starts agitating same time it's filling up hrscales Washer Repair 3 04-03-2009 05:27 PM
starts & stops epk Dryer Repair 2 11-20-2007 07:45 AM
Starts to pump during wash then shuts down, starts, stops real quidk sirgalagit Dishwasher Repair 1 10-03-2007 08:23 PM
