Discuss
Black shavings under washer and brake squeal
 in
Washer Repair
There are black shavings under this new machine and the brake started squealing. Any thoughts? Thanks, George
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Black shavings under washer and brake squeal
  #1 (permalink)
Old 03-21-2008, 08:59 PM
GeorgeG GeorgeG is offline
Member
GeorgeG is on a distinguished road
Default Black shavings under washer and brake squeal
Model Number: WTW5520SQ0   Brand: Whirlpool   Age: Less than 1 year
Thanks,
George
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-22-2008, 04:10 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I would get warranty service on this, seems like your coupler is going bad and you have dragging brake shoes, potentially a serious problem to get fixed soon.
__________________
  #3 (permalink)
Old 03-23-2008, 11:41 AM
Member
Default
Rich
Where can I find your link on testing for dragging brakes? Why would the brakes start to stick so soon? Can the coupler fail and squeak with good brakes?
Thanks,
George
  #4 (permalink)
Old 03-24-2008, 02:45 AM
Senior Expert
APP Volunteer
Default
The brake shoe cam rollers wear out due to cheap metal. Go to my article in the general talk section, page 3 "replacing direct drive washer brake shoes".
__________________
  #5 (permalink)
Old 03-24-2008, 10:42 PM
Member
Default
The motor coupler was fine. The brake shoes were a mess. Powder and particles all over the top of the trans and in the clutch bowl/pads. I put in a new brake tube and after 2 cycles all seems well. Why would new brakes self destruct like that? Also, I bypassed the lid switch to watch the cycles. I noticed that during an empty spin, the basket has a hitch to it. The spin is fairly smooth and then the basket jerks to the side at a rate of 2-3 times per second. Is that normal?
Thanks,
George
  #6 (permalink)
Old 03-25-2008, 04:05 AM
Senior Expert
APP Volunteer
Default
I have seen this a lot. Transmissions will develop a twitch like that, it is internal to the tranny. Only way to fix this is a new tranny, but it will be ok as it is. You can put a 6 inch long helper spring on the back frame to help this. It will firm up the suspension.
__________________
  #7 (permalink)
Old 04-17-2008, 10:16 AM
Member
Default
I have discovered 2 things during re-assembly. Not all drive blocks are created equal. Run the washer in spin after the drive block is installed to make sure that it is not way out of round. Also, if you try indexing the the tub on the block in 90 degree increments you will find a position that runs much smoother than some of the other positions (like a car tire and wheel).
George
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing direct drive washer brake shoes richappy General Talk 2 08-04-2008 03:03 AM
Amana washer hot smell and does not brake quickly at end of spin cycle RandyToby1 Washer Repair 0 03-21-2008 06:59 PM
Maytag Washer Brake Repair Question RichL Washer Repair 2 02-06-2008 04:14 PM
Compact GE Front Load Plastic Shavings LeslieJ Washer Repair 0 02-04-2008 12:06 PM
Washer leaves black marks when using cold water triskit22 Washer Repair 1 09-19-2007 06:35 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
