Discuss
replacing the clutch on a Whirlpool washer
 in
Washer Repair
Hi, I have a 5-6 year old Whirlpool Ultimate care washer (LSQ9659PW0) that agitates but does not spin. It has
Appliance Repair Forum > Appliance Repair Help > Washer Repair » replacing the clutch on a Whirlpool washer
  #1 (permalink)
Old 12-25-2009, 10:28 AM
Junior Member
boselam is on a distinguished road
Default replacing the clutch on a Whirlpool washer
Model Number: LSQ9659PW0   Brand: Whirlpool   Age: 5 - 10 years
I have a 5-6 year old Whirlpool Ultimate care washer (LSQ9659PW0) that agitates but does not spin. It has been diagnoses as having a bad clutch but the appliance repair company that I contacted to look at the washer has indicated that they will not repair the clutch without also replacing the basket drive. The total price for the repairs would be nearly $300 (labor and parts) in which case it might make more sense to buy a new washer but this seems a bit premature. I would like to do the repairs myself and to replace only the clutch but wanted to get a second opinion before diving in. Alternatively, is there any way I can examine the basket drive to make a visual determination if it too needs repaired? Any finally can I drop out the transmission from below on this washer so I don't need to take out the entire basket??? Some information that I found online implied that this was possible indicating that the gearcase mounting bolts that could be removed from below.
Any advice or suggestions that you might have would be appreciated.
Thanks,
Mike
Related Models
Whirlpool LSQ9659PW0 AUTOMATIC WASHER
Whirlpool LSQ9659PW1 AUTOMATIC WASHER
Whirlpool LSQ9659PW2 AUTOMATIC WASHER
Whirlpool LSQ9659PW3 AUTOMATIC WASHER
Whirlpool LSQ9659PW4 AUTOMATIC WASHER
Whirlpool LSQ9660PG0 AUTOMATIC WASHER
Whirlpool LSQ9660PG1 AUTOMATIC WASHER
Whirlpool LSQ9660PG2 AUTOMATIC WASHER
Whirlpool LSQ9660PG3 AUTOMATIC WASHER
Whirlpool LSQ9660PG4 AUTOMATIC WASHER
Whirlpool LSQ9660PW0 AUTOMATIC WASHER
Whirlpool LSQ9660PW1 AUTOMATIC WASHER
Whirlpool LSQ9660PW2 AUTOMATIC WASHER
Whirlpool LSQ9660PW3 AUTOMATIC WASHER
Whirlpool LSQ9660PW4 AUTOMATIC WASHER
Whirlpool LSQ9665JQ0 WASHER
Whirlpool LSQ9665JQ1 WASHER
Whirlpool LSQ9665JQ2 WASHER
Whirlpool LSQ9665JQ3 WASHER
Whirlpool LSQ9665JQ4 WASHER
Whirlpool LSQ9665JT0 WASHER
Whirlpool LSQ9665JT1 WASHER
Whirlpool LSQ9665JT2 WASHER
Whirlpool LSQ9665JT3 WASHER
Whirlpool LSQ9665JT4 WASHER
Whirlpool LSR4100HQ0 AUTOMATIC WASHER
Whirlpool LSR4311DQ0 WASHER
Whirlpool LSR5100HQ0 AUTOMATIC WASHER
Whirlpool LSR5100KQ0 RESIDENTIAL WASHER
Whirlpool LSR5100LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ1 AUTOMATIC WASHER
Whirlpool LSR5102LQ1 AUTOMATIC WASHER
Whirlpool LSR5121HQ0 AUTOMATIC WASHER
Whirlpool LSR5121JQ0 AUTOMATIC WASHER,
Whirlpool LSR5132AG0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AN0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AW0 DIRECT-DRIVE WASHER
Whirlpool LSR5132HQ0 AUTOMATIC WASHER
Whirlpool LSR5132HQ1 AUTOMATIC WASHER
Whirlpool LSR5132JQ0 COMPACT WASHER
Whirlpool LSR5132JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR5132JQ2 WASHER - DIRECT DRIVE
Whirlpool LSR5132PQ0 AUTOMATIC WASHER
Whirlpool LSR5132PQ1 AUTOMATIC WASHER
Whirlpool LSR5132PQ3 AUTOMATIC WASHER
Whirlpool LSR5132PQ4 AUTOMATIC WASHER
Whirlpool LSR5232DW0 AUTOMATIC WASHER
Whirlpool LSR5232LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5232LQ1 AUTOMATIC WASHER
Whirlpool LSR5233AG0
Whirlpool LSR5233AN0
Whirlpool LSR5233AW0 Washers*
Whirlpool LSR5233EQ0 AUTOMATIC WASHER
Whirlpool LSR5233EQ1 DIRECT-DRIVE WASHER
Whirlpool LSR5233EQ2 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132BN0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW1 AUTOMATIC WASHER
Whirlpool LSR6132DQ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132DZ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132EQ0 AUTOMATIC WASHER
Whirlpool LSR6132EQ1 AUTOMATIC WASHER
Whirlpool LSR6132EZ0 AUTOMATIC WASHER
Whirlpool LSR6132EZ1 AUTOMATIC WASHER
Whirlpool LSR6132HQ0 AUTOMATIC WASHER
Whirlpool LSR6132HQ1 AUTOMATIC WASHER
Whirlpool LSR6132HZ0 AUTOMATIC WASHER
Whirlpool LSR6232JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR6232JQ1 WASHER - DIRECT DRIVE
Whirlpool LSR6232JQ2 AUTOMATIC WASHER
Whirlpool LSR6233BG0 AUTOMATIC WASHER
Whirlpool LSR6233BN0 AUTOMATIC WASHER
Whirlpool LSR6233BN1 WASHER
Whirlpool LSR6233BW0 AUTOMATIC WASHER
Whirlpool LSR6233BW1 WASHER
Whirlpool LSR6233DN0 AUTOMATIC WASHER
Whirlpool LSR6233DW0 AUTOMATIC WASHER
Whirlpool LSR6244AW0 Washers*
Whirlpool LSR6332KQ0 WASHER
Whirlpool LSR6332KQ1 AUTOMATIC WASHER
Whirlpool LSR6334LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR6334LQ1 AUTOMATIC WASHER
Whirlpool LSR6335LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR7010PQ0 AUTOMATIC WASHER
Whirlpool LSR7010PQ1 AUTOMATIC WASHER
Whirlpool LSR7010PQ2 AUTOMATIC WASHER
Whirlpool LSR7133KQ0 WASHER
Whirlpool LSR7133KQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ0 AUTOMATIC WASHER
Whirlpool LSR7133PQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ2 AUTOMATIC WASHER
Whirlpool LSR7200EQ0 AUTOMATIC WASHER
Whirlpool LSR7200EZ0 AUTOMATIC WASHER
Whirlpool LSR7233BG0
Whirlpool LSR7233BG1
Whirlpool LSR7233BG2
Whirlpool LSR7233BGO WASHER
Whirlpool LSR7233BN0
Whirlpool LSR7233BN1
Whirlpool LSR7233BN2
Whirlpool LSR7233BNO WASHER
Whirlpool LSR7233BQ0
Whirlpool LSR7233BQ1
Whirlpool LSR7233BQ2
Whirlpool LSR7233BQO WASHER
Whirlpool LSR7233BW0
Whirlpool LSR7233BW1
Whirlpool LSR7233BW2
Whirlpool LSR7233BWO WASHER
Whirlpool LSR7233BZ0
Whirlpool LSR7233BZ2
Whirlpool LSR7233DQ0 WASHER
Whirlpool LSR7233DQ1 AUTOMATIC WASHER
Whirlpool LSR7233DW0 WASHER
Whirlpool LSR7233DZ0 WASHER
Whirlpool LSR7233DZ1 AUTOMATIC WASHER
Whirlpool LSR7233EQ0 WASHER
Whirlpool LSR7233EQ1 AUTOMATIC WASHER
Whirlpool LSR7233EW0 DIRECT-DRIVE WASHER
  #2 (permalink)
Old 12-25-2009, 04:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can find some useful information in our previous posts: Replacing direct drive washer brake shoes and not spinning
- The clutch assembly Part number: AP3094537
- The basket drive Part number: AP3094539
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSQ9659PW0 Automatic Washer | AppliancePartsPros.com
Here is the Service manual.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-26-2009, 02:51 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
If the motor is running in spin, you just might have dragging brake shoes. Do the test in my "sticky" replacing direct drive brake shoes. Dragging brake shoes will wear out the clutch.
__________________
  #4 (permalink)
Old 12-28-2009, 05:13 PM
Junior Member
Default
Gene and Richappy,
I just got back home from visiting relatives and pulled the basket out of the washer to check the drive block and spin tube per your suggestions in earlier posts. Both loooked great with no obvious signs of damage or wear.
The two major culprits left are the clutch and basket drive/brake assembly, which brings me back to my original problem of trying to determine if both need replaced or if I can get by with the clutch alone. I am pretty sure the clutch is bad. Before I took the basket out when I would turn the clutch from below it frequently slipped and would not grab the basket. Also, when I tried to turn the transmission spindle using the tranny coupler per richappy's suggestion ("Replacing direct drive washer brake shoes") it was hard to turn. Without pliers I needed to use both of hands (grabbing two separate tabs) to turn the spindle and I had the basket off at the time. In contrast I don't have any evidence that the brakes are bad. There was never a problem with thumping noises or vibrations when the spin cycle ended. I have not taken the transmission off to get at the clutch yet but am planning to do so tomorrow. Do you think I will need to drop the spin tube and examine the brake pads and shoes or can I proceed with just the clutch repairs. I am worried that tearing into the brakes might be pushing it a bit for my skill level even with the instructions in the "Replacing direct drive washer brake shoes" post. I want to do the repairs as cheaply as possible because my wife is all for buying a new washer but I don't want it to break again after just a few loads. Any advice? Is there a website with illustrations or photos that you can recommend?
Also, a few other questions.....
1. The top half of the center post that the basket ifits over was pretty corroded. The paint has flaked off and there was some rusting of the metal. Is this just cosmetic?
2. The plastic fitting at the top of the basket (P/N 8519788) contains water that I can hear swishing around inside. Is this normal? There is a plug on the rim that loooks like it could be looosened with a phillips screw driver to drain the water but it indicates that the plug is not removable.
And (as an aside) for other do-it-your-selfers reading this post, the spanner nut was real easy to get off! I was worried that I was going to have to buy a spanner wrench but a hammer and a 3 inch socket wrench extension worked great (it gave a better angle than a screwdriver).
Thanks much,
Mike
  #5 (permalink)
Old 12-28-2009, 06:51 PM
Senior Expert
APP Volunteer
Default
If the tranny coupler was very hard to turn, just replace the brake shoes per the instructions in my sticky.
__________________
  #6 (permalink)
Old 12-30-2009, 10:08 AM
Junior Member
Default
I dropped the transmission this morning and examined the clutch and basket drive per your sticky on replacing brake shoes. As expected the clutch ring was easy to turn in the housing (I could move it using just my pinkie finger) so I am probably going to need to get a new clutch. I have included a photo of the clutch assembly with this post.
The bottom of the basket drive looked fine (see photos) and the brake shoes did not seem to be sticking since the spin tube was easy to turn, using the plastic cam as a handle. I pulled the spin tube out enough to see the surface of the brake pads but I did not dissasemble it any further to examine the brake shoe rollers because I do not know where to find them at in the assembly. Do I need to examine these or can I focus my attention on the clutch repairs at this time without making any changes to the basket drive.
Also, since I am a newbie at this can you elaborate on what it means to check the brake shoe cam rollers for "excessive play" and is this possible to evaluate without taking the brake apart any further? The plastic cam had about 30 degrees of give to it (before pushing on the 'release arms' of the brake shoes. Is this a measure of the degree of play?
And one final question......
When I was removing the transmission and sliding the agitator shaft out of the spin tube a small brass pin dropped onto the floor. The pin is about 2 inches long and has a head like a nail and a small hole at the end of the shaft which was lubricated with a clear grease. Do you know where this came from on the washer? Does it fit in the end of the agitator shaft? I could not find anything like it in the parts diagrams for the washer. I did not think to take a picture but I could do so later today.
Thanks much!
Mike
  #7 (permalink)
Old 12-30-2009, 02:04 PM
Senior Expert
APP Volunteer
Default
To check the cam rollers on the brake shoes, just push on them, if there is a lot of play in them, they are worn out.
__________________
  #8 (permalink)
Old 01-01-2010, 06:43 AM
Junior Member
Default
I pulled out the drive block and partly disassembled the brake to see the rollers. All I had to do was to take off the C clip and the plastic cam as shown in the photos.
One of the rollers (of the outer/primary brake show) was somewhat difficult to see but I could get a better view and could rotate both rollers by pressing in on the brake pads. Neither roller had ‘excessive play’ as best as I could assess. There was good contact between the shoes and the roller when the drive block was out but when I put I back inside the drum the brake pad were pushed back in towards eachother a bit such that the release arms of the shoes no longer contacted the rollers and the plastic c am had a bit of give (moving 30 degrees before contacting the rollers and releasing the backs) but I can’t imagine that this is a problem.
I have ordered a new clutch and will put it in early next week. My only remaining concern relates to the brass pin that fell out when I dropped the transmission as was mentioned in my earlier post. It is about two inches long and its shaft is flat on one side and rounded on the other with a hole at the end. It does not seem to fit in the end of the agitator spindle or the transmission. I have included a picture with this post. Any suggestions about where it belongs on the washer would be much appreciated.
Thanks and Happy New Year to others on the forum!
Mike
  #9 (permalink)
Old 01-01-2010, 01:19 PM
Junior Member
cptbob88 is on a distinguished road
Default I've got the same pin.
I've got the same pin that fell out. Mine had a broken motor/pump coupler - $30 fix. But now that I've got it all back together again, it still won't agitate or spin. Pump works fine and this pin looks an awful lot like a retaining pin on car brakes. But I don't see a loose spring, or obvious tension point where it would have been. I'm pulling it all back apart currently. Thanks for the insights on this post!! Bob N>>
Update: There were 2 of these pins. They are the shipping pins that fall out when then the original shipping strap is removed from the back of the washer. They are usually caught in the little clear plastic cups that are attached to the base. When you turn the washer over or invert it, the pins can end up anywhere.
  #10 (permalink)
Old 01-02-2010, 01:42 AM
Senior Expert
APP Volunteer
Default
If the motor runs, pull it apart again and post results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Top Load Washer Clutch Ring Retainer teddy99520 Washer Repair 3 03-12-2011 01:49 AM
Replacing the belt on a whirlpool washer Escargot58 Dishwasher Repair 0 09-25-2009 02:22 PM
replacing a retaining clip for clutch on hotpoint washer johnice Washer Repair 1 03-13-2009 04:24 AM
help replacing clutch rednran Washer Repair 5 02-14-2008 06:27 AM
Whirlpool Clutch Replacement bermudabye Washer Repair 1 01-07-2008 07:19 AM
