Discuss
Washer
 in
Washer Repair
Iam needing information on putting the trans. shaft along with trans. and motor attacthed back into basket. The shaft go
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer
  #1 (permalink)
Old 12-24-2009, 06:17 AM
Junior Member
realistic is on a distinguished road
Thumbs up Washer
Model Number: 11022292100   Brand: Kenmore   Age: More than 10 years
Iam needing information on putting the trans. shaft along with trans. and motor attacthed back into basket. The shaft go so far then stop. It feels like a lip is preventing me from popping right in. Please help me!
Ads By Google
Related Models
Kenmore 11022292100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022294100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022422100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022432100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022442100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022622100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022632100 WASHER
Kenmore 11022642100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022652100 COMPACT WASHER
Kenmore 11022662100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692101 AUTOMATIC WASHER
Kenmore 11023012100 AUTOMATIC WASHER
Kenmore 11023012101 AUTOMATIC WASHER
Kenmore 11023012102 AUTOMATIC WASHER
Kenmore 11023014100 AUTOMATIC WASHER
Kenmore 11023014101 AUTOMATIC WASHER
Kenmore 11023014102 AUTOMATIC WASHER
Kenmore 11023022100 AUTOMATIC WASHER
Kenmore 11023022101 AUTOMATIC WASHER
Kenmore 11023022102 AUTOMATIC WASHER
Kenmore 11023024100 AUTOMATIC WASHER
Kenmore 11023024101 AUTOMATIC WASHER
Kenmore 11023024102 AUTOMATIC WASHER
Kenmore 11023032100 WASHER
Kenmore 11023032101 AUTOMATIC WASHER
Kenmore 11023032102 AUTOMATIC WASHER
Kenmore 11023034100 WASHER
Kenmore 11023034101 AUTOMATIC WASHER
Kenmore 11023034102 AUTOMATIC WASHER
Kenmore 11023036100 WASHER
Kenmore 11023036101 AUTOMATIC WASHER
Kenmore 11023036102 AUTOMATIC WASHER
Kenmore 11023652200 AUTOMATIC WASHER
Kenmore 11023662200 AUTOMATIC WASHER
Kenmore 11023692200 AUTOMATIC WASHER
Kenmore 11023712200 AUTOMATIC WASHER
Kenmore 11023722200 AUTOMATIC WASHER
Kenmore 11023732200 AUTOMATIC WASHER
Kenmore 11023812100 AUTOMATIC WASHER
Kenmore 11023822100 AUTOMATIC WASHER
Kenmore 11023832100 AUTOMATIC WASHER
Kenmore 11023902200 AUTOMATIC WASHER
Kenmore 11023902201 AUTOMATIC WASHER
Kenmore 11023904200 AUTOMATIC WASHER
Kenmore 11023904201 AUTOMATIC WASHER
Kenmore 11023912100 AUTOMATIC WASHER
Kenmore 11023912101 AUTOMATIC WASHER
Kenmore 11023912102 AUTOMATIC WASHER
Kenmore 11023922200 AUTOMATIC WASHER
Kenmore 11023922201 AUTOMATIC WASHER
Kenmore 11023924200 AUTOMATIC WASHER
Kenmore 11023924201 AUTOMATIC WASHER
Kenmore 11023932200 WASHER
Kenmore 11023934200 WASHER
Kenmore 11024082200 AUTOMATIC WASHER
Kenmore 11024084200 AUTOMATIC WASHER
Kenmore 11024086200 AUTOMATIC WASHER
Kenmore 11024422300 AUTOMATIC WASHER
Kenmore 11024432300 AUTOMATIC WASHER
Kenmore 11024442300 AUTOMATIC WASHER
Kenmore 11024622300 AUTOMATIC WASHER
Kenmore 11024632300 AUTOMATIC WASHER
Kenmore 11024642300 AUTOMATIC WASHER
Kenmore 11024652300 AUTOMATIC WASHER
Kenmore 11024692300 AUTOMATIC WASHER
Kenmore 11024812200 AUTOMATIC WASHER
Kenmore 11024812201 AUTOMATIC WASHER
Kenmore 11024822200 AUTOMATIC WASHER
Kenmore 11024822201 AUTOMATIC WASHER
Kenmore 11024832200 AUTOMATIC WASHER
Kenmore 11024832201 AUTOMATIC WASHER
Kenmore 11024892300 AUTOMATIC
Kenmore 11024894300 AUTOMATIC
Kenmore 11024902200 AUTOMATIC WASHER
Kenmore 11024902201 AUTOMATIC WASHER
Kenmore 11024904200 AUTOMATIC WASHER
Kenmore 11024904201 AUTOMATIC WASHER
Kenmore 11024922200 AUTOMATIC WASHER
Kenmore 11024922201 AUTOMATIC WASHER
Kenmore 11024924200 AUTOMATIC WASHER
Kenmore 11024924201 AUTOMATIC WASHER
Kenmore 11024932200 AUTOMATIC WASHER
Kenmore 11024932201 AUTOMATIC WASHER
Kenmore 11024934200 AUTOMATIC WASHER
Kenmore 11024934201 AUTOMATIC WASHER
Kenmore 11024942300 AUTOMATIC WASHER
Kenmore 11024944300 AUTOMATIC WASHER
Kenmore 11024946300 AUTOMATIC WASHER
Kenmore 11024952300 AUTOMATIC WASHER
Kenmore 11024954300 AUTOMATIC WASHER
Kenmore 11024956300 AUTOMATIC WASHER
Kenmore 11024962300 AUTOMATIC WASHER
Kenmore 11024964300 AUTOMATIC WASHER
Kenmore 11024966300 AUTOMATIC WASHER
Kenmore 11024972300 AUTOMATIC WASHER
Kenmore 11024974300 AUTOMATIC WASHER
Kenmore 11024982300 AUTOMATIC WASHER
Kenmore 11024992300 AUTOMATIC WASHER
Kenmore 11024994300 AUTOMATIC WASHER
Kenmore 11024996300 AUTOMATIC WASHER
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
Kenmore 11026292693 AUTOMATIC WASHER
Kenmore 11026292694 WASHER
Kenmore 11026292695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026294690 AUTOMATIC WASHER
Kenmore 11026294691 AUTOMATIC WASHER
Kenmore 11026294692 AUTOMATIC WASHER
Kenmore 11026294693 AUTOMATIC WASHER
Kenmore 11026294694 WASHER
Kenmore 11026294695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026702694 AUTOMATIC WASHER
Kenmore 11026722690 WASHER
Kenmore 11026801690 AUTOMATIC WASHER
Kenmore 11026812690 WASHER
Kenmore 11026814690 WASHER
Kenmore 11026822690 WASHER
Kenmore 11026824690 WASHER
  #2 (permalink)
Old 12-24-2009, 08:03 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I would take off the motor as it makes it easier to work with the transmission.
You are probably have the brake release cam (that white plastic thing) hit the clutch spring. Slide the transmission in and then gently push on it while turning the clutch. and wiggling the transmission. You should be able to get it to in snug up against the screw holes.
Good luck, hope this helps.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
help how do you speciffically replace washer timer on Maytag washer stupid1 Washer Repair 5 07-04-2009 05:21 PM
is this model number washer a direct drive washer dandjwashington Washer Repair 2 05-01-2009 07:26 PM
Change Washer Lid Switch on Stacked Washer/Dryer scottcomputers Washer Repair 1 05-01-2009 10:16 AM
maytag washer/dyer combo washer no water lindavanzandt Washer Repair 0 11-30-2008 08:35 AM
