I am tring to remove basket off of the transmission shaft?
Originally Posted by: realistic I am tring to remove basket off of the transmission shaft? I am removing the basket from the trans shaft to replace the basket. I am stuck athe hub .I need to know how to remove please help me!!!
Remove the washer cabinet (instructions attached). Remove the tub ring unsnapping the tub ring tabs from the tub one at a time. Remove the agitator cap. Unscrew the agitator mounting bolt, and remove agitator. Next step is to remove the spanner nut. You can do it using a hummer and a screwdriver or you can buy a special spanner wrench . However, it is recommended to use the special spanner wrench to properly tighten the spanner nut at the end of the repair. Carefully remove the basket by lifting straight up. Gene.
