Discuss
GE Washer hub nut loosens
 in
Washer Repair
I just received the washer from some guy, and it worked awesome for three weeks, then it started making a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer hub nut loosens
  #1 (permalink)
Old 12-22-2009, 02:35 PM
Junior Member
heinzincew is on a distinguished road
Default GE Washer hub nut loosens
Model Number: S3700G0WW   Brand: GE   Age: 1 - 5 years
I just received the washer from some guy, and it worked awesome for three weeks, then it started making a noise during the spin cycle. The noise got louder with every load, so I had to investigate. What I found was the hub nut was loose causing the basket to rub on the bottom of the tub, and the split ring was shrinking, there was metal dust from the split ring all over in the tub and around the hub. So I purchase a new hub washer, split ring, hub nut, and drive bell and reassembled everything. I have a channelocks that fit inside the tub to tighten the hub nut, and had another channelocks on the shaft below the tub to tighten it as good as I could with that. Anyways, it worked for a few loads, then I noticed it getting a little louder in the spin cycle and found that the hub nut had come loose again. I am wondering if there is supposed to be a "key" in the hub that fits into the "split" of the split ring and it was just worn out when the nut first came loose(that is, should I replace the hub?), or do I just need to add some locktite and crank on the hub nut harder with a pipe wrench or something? Can I use a pipe wrench on the shaft under the tub? Also, any ideas on what happened to cause the nut to come loose in the first place? Thank you so much for any help you can offer.
Related Models
General Electric S3700G0WW Washer
General Electric S3700G1WW WASHER
General Electric S3700G2WW WASHER
General Electric S3700G3WW WASHER
General Electric S3700G4WW WASHER
General Electric S3700G5WW WASHER
General Electric S3700G6WW WASHER
Hoover S3755--- CSTR-SPHERICAL,SAUCER,LC,ELEC,TP SWIVEL
Hoover S3755080 CSTR-SPHERICAL,SAUCER,LC,ELEC,TP SWIVEL
Hoover S3765040 CSTR-SPHERICAL,SAUCER,LC,ELEC,TP SWIVEL
Magic Chef S38FA-2CX-94 RANGE- S/C F/S ELE
Magic Chef S38FK-2CX-94 RANGE- S/C F/S ELE
Magic Chef S38FK-2CX-OC RANGE- S/C F/S ELE
Magic Chef S38FY-2CX-94 RANGE- S/C F/S ELE
Admiral S40STRP REF - TOP MOUNT
Frigidaire S418B2SA Kel(v0) / Room Air Conditioner
Frigidaire S418C2SB Kel(v1) / Room Air Conditioner
Frigidaire S418F2XA Kel(v1) / Room Air Conditioner
Frigidaire S418T2SA Kel(v4) / Room Air Conditioner
General Electric S4200B0WW Washer
General Electric S4200B1WW Washer
General Electric S4200B2WW Washer
General Electric S4200B3WW Washer
Roper S4257*0 SLIDE-IN GAS RANGE
Roper S4257W0 SLIDE-IN GAS RANGE
Roper S5007W0 Ranges, Electric*
Hoover S5083
General Electric S5100D0WW Washer
General Electric S5100D1WW Washer
Magic Chef S51FK-2KLX-64 RANGE- D/I CONT CLEAN GAS
Magic Chef S51FK-2KLX-ON RANGE- D/I CONT CLEAN GAS
General Electric S5200E1WW Washer
General Electric S5200E6WW Washer
Hoover S5501---
Hoover S5503---
Hoover S5507---
Hoover S5509---
Hoover S5509021
Hoover S5511---
Hoover S5513---
Hoover S5533---
Hoover S5535---
Hoover S5537---
Hoover S5539---
Hoover S5549
Hoover S5567011
Hoover S5569011
Hoover S5573--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5573011
Hoover S5573022
Hoover S5573033
Hoover S5575---
Hoover S5575001
Hoover S5577--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5579---
Hoover S5581---
Hoover S5583---
Hoover S5585---
Hoover S5587---
Hoover S5589---
Hoover S5593---
Hoover S5601--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5602070 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5604070 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5604080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5605 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5607---
Hoover S5609--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5610--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5610070 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5610080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5613--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5615--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5619--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5620--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5620070 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5625--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5626--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5627 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5627080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5630--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5635--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5636--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5639---
Hoover S5640--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5643--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5645---
Hoover S5645001
Hoover S5647---
Hoover S5649---
Hoover S5651---
Hoover S5655--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5668--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5669--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5671--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5672--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5673--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5673080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5674--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5675--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5675080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5676--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5677--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5678--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5680--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5682--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5684--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5684035 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5686--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5688--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5690--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5692--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5697--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5701--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5701035 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5703--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5709--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5711--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5713--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5715--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
  #2 (permalink)
Old 12-22-2009, 04:20 PM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
You need to pound on that left hand thread tub nut with a special spanner wrench available on this parts site, will never get it tight with a pipe wrench.
__________________
  #3 (permalink)
Old 12-22-2009, 08:42 PM
Junior Member
Default
I can only find spanner wrench part number AP4503397, but this lists only Maytag washers. Will it work for my GE washer? Also, Do I need to hold the shaft with a pipe wrench or just pound on the spanner wrench and leave the shaft able to spin like an impact to the wrench? Thanks again for your help.
  #4 (permalink)
Old 12-23-2009, 02:24 AM
Senior Expert
APP Volunteer
Default
You must use the GE spanner wrench and NOT a universal one. You will never get it tight enough with the universal one and you should use a heavy hammer on it. Also, inspect all surfaces, if any are worn out, you will have problems.
__________________
  #5 (permalink)
Old 12-23-2009, 12:50 PM
Admin / APP Team's Avatar
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
This is the GE spanner wrench. Pretty expensive. We are checking to see if the less expensive Gemline spanner wrench still comes with the GE adapter. Last I heard, it no longer did. I will post an update once we get the info.
Part number: AP2614008
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #6 (permalink)
Old 12-23-2009, 01:06 PM
Administrator
APP Team
Default
Looks like the Gemline / PRO spanner wrench DOES include the GE adapter. It's about a third of the price of the GE wrench. What do you think, Rich? Will it be good enough?
Good in stock. Part number: AP4503397
__________________
  #7 (permalink)
Old 12-23-2009, 02:22 PM
Senior Expert
APP Volunteer
Default
You might want to post the use of this wrench to get other inputs. I have the identical wrench and found it virtually unusable to remove the usually jamed GE tub nut. Like using a cheap sheet steel socket on a hot water heater element, it's just too sloppy a fit to get the element out. I use a pro. socket for this and I ground it down to get the best grip on the element.
If you compare the two pictures, you will see the expensive one has precision cut socket surfaces, while the other one has cast surfaces.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Change Washer Lid Switch on Stacked Washer/Dryer scottcomputers Washer Repair 2 10-15-2015 12:39 PM
maytag washer/dyer combo washer no water lindavanzandt Washer Repair 1 01-18-2015 07:44 PM
help how do you speciffically replace washer timer on Maytag washer stupid1 Washer Repair 5 07-04-2009 06:21 PM
is this model number washer a direct drive washer dandjwashington Washer Repair 2 05-01-2009 08:26 PM
